Results 1 to 10 of 11
Thread: what devices require 2000w inverter
    Mar 2010
    victoria
    Hi all,
    I'm going to take the plunge and get lithium for aux in the near future.
    One of the salesmen I have been speaking with gave me a few options.
    12V 100Ah / 100A LiFePO4 battery
    12V 100Ah / 175A LiFePO4 battery
    12V 150Ah / 100A LiFePO4 battery
    12V 150Ah / 175A LiFePO4 battery
    12V 200Ah / 100A LiFePO4 battery
    12V 200Ah / 175A LiFePO4 battery
    He mentioned the 175A would allow the use of a 2000w inverter.
    My only real need for an inverter would to charge a laptop so I don't think I need 2000w but I am curious what type of devices would require such high wattage? Or is it more about the quantity of things being used at the same time?
    And if my laptop is charged via USB C, do I need an inverter at all? Or will a USB C fast charge plug suffice? such as
    Server Busy
    Apr 2019
    Koojan WA (part time Perth)
    Quote Originally Posted by BreakingBad View Post
    Hi all,
    Server Busy
    Microwave
    Hairdryer
    Coffee machine
    Big screen TV
    Just the essentials whilst travelling 🤪
    1985 110 Dual Cab 4.6 R380 ARB Lockers (currently NIS due to roof kissing road)
    1985 110 Station Wagon 3.5 LT85 (unmolested blank canvas)
    Apr 2016
    Country Vic.
    Yep!
    .... Or is it more about the quantity of things being used at the same time?
    oops! sorry yep to this part.
    But also, a single item can draw 2000w too. Think .... kettle(or fast boil kettle), microwave, induction cooktops.
    You're probably laughing right now thinking to yourself who would take a kettle or microwave camping?
    From what I've seen .. they do!
    But more so the caravanners use them.
    You can get lower voltage appliances(such as microwaves), but are horrendously expensive. Can't remember if they're 12 or 24v(maybe both).
    Check the power rating for your USB-C charger, should be easy to find a plug for it. From memory the Microsoft USB charger for their tablet/laptop thingies are rated at 45w. My daughter had one for school, and I got her a wall plug for her while she was with me. I recall 45w was about what it was rated at. 12v into USB at 45w should be easy .. just don't go cheapo!
    Arthur.
    '03 D2 Td5 Auto
    '03 D2a Td5 Auto
    Apr 2019
    We ditched gas for induction cooktop therefore upgraded to lithium
    200ah battery with 200amp max. draw
    Max we run the induction cooktop is 1800w, which is when we are boiling water and it pulls 162amps.
    May 2021
    Mackay
    If you don't use the capacity, it is inefficient at light loads. You're better to match the inverter to expected loads. On the boat, I use a (relatively expensive) Projecta 600w pure sine wave inverter for charging laptops and cordless power tool batteries, and also keep an Ebay cheapy 1500w pure sine wave (allegedly!) inverter for running basically the missus's toaster and the wet and dry vacuum cleaner occasionally. In the car we use a 130 w inverter for ac battery chargers and a 12v to 5v 10A power brick and USB power outlets for charging USB stuff which works out really well - especially with a load of grand kids onboard.
    Mar 2015
    Horsham Victoria
    Electric blankets 600 watt from what I read in 4x4 magazine, fella had one in a patrol decked out to sleep in.
    DiscoMick Guest
    We went for the same Enerdrive 200 amp lithium battery with 2000 inverter, chargers and 300 watts of solar on our new caravan.
    Only used it once, but I can happily confirm it can run our Aldi coffee pod machine and also the frother, but not both at the same time.
    Also happy to find the solar replaces the charge used within about half an hour if the sun is shining.
    Haven't used it enough yet to comment on anything else.
    I'm not expecting a problem with our eBay cheapie 12V electric blanket, as we only run it on low in cold weather, and it was no problem in our previous camper trailer. 12V is the way to go.
    Quote Originally Posted by W&KO View Post
    Queensland
    Quote Originally Posted by Gav 110 View Post
    Microwave
    Hairdryer
    Coffee machine
    Big screen TV
    I only use large inverters at home, during power blackouts, so have no real idea of the use and power consumption of these and other devices mentioned.
    What sort of power consumption does each device require and how long do you run them for?
    Big screen TVs use very little power. I have a large screen plasma TV and run it plus my DVD and Foxtel unit from a 750w inverter, that also runs a few 240vac lights, all at the same time.
    Apr 2019
    Hi Drivesafe
    I don’t actually use one myself, I carry a 150watt pure sine wave inverter whilst camping, only if I have to fire up the laptop for work
    My comments were based on observations of other people’s camp setups
    what devices require 2000w inverterwhat devices require 2000w inverterwhat devices require 2000w inverter
    Gav
    Queensland
    Hi Drivesafe
    Gav
    Hi Gav, thats as big an inverter as I use, to recharge all my video gear.
    I was after feedback on what people actually use something like a 2,000w inverter for.
    I have lots of customers who use these, to run a hair dryer, jug, toaster and even a microwave, all powered from lead acid batteries, but I have never bothered to find out how much 240vac power they draw and how long they run these devices.
    I am only interested in those doing this in their Landy, not in a camper trailer, caravan or motor home, because theses are a different situation.
