[QUOTE=LiamO;3105966]
Originally Posted by
I am not understanding your problem. From your pictures, the new collar is about 1mm thicker than the one that is replaced. While it may be a little concerning that it is not identical to the original, the only effect of this will be to widen the track by about 1mm, which is within the amount you could expect for manufacturing tolerance and wear on the inner wheel bearing. (It will also move the position of the brake shoes relative to the drum by the dame amount, but the same comment applies.
It is possible it is deliberately wider because some combination of seal and manufacturing tolerance allowed the seal to touch the flange of the stub axle.[/QUOTE]
Thanks John - All of that is not required if the collar/seal matched the original, right. My understanding and please correct if wrong, is that the stub axel should slide fully over collar/seal, not just half way?
As long as the inner lip of the seal sits on the collar it's OK and as John said......it might make the track wider by a small amount but that won't cause any problems.
Colin
'65 Series IIa Dormobile
'70 SIIa GS
'76 SIII 88" (Isuzu C240)
'81 SIII FFR
'95 Defender Tanami
Motorcycles :-
