Results 1 to 3 of 3
Thread: Re-wire - estimate of how big a job it is
    Mar 2010
    victoria
    Hi
    I am curious as to how much effort is required to rewire a 300tdi defender.
    I gather it takes a bit of time/effort but is it a day job, a full weekend or even couple of weekends worth of time/effort?
    Can it be done by an amateur or does it require an auto elec?
    Can it be done in stages?
    Do I need the pre made loom(s) or can they be made up - possibly with better/thicker wires. Is that even necessary?
    Is it worth replacing relays/fuse boxes at the same time or is that just waste of time/effort and money?
    regards
    Nov 2015
    Black Rock
    Quote Originally Posted by BreakingBad View Post
    Hi
    regards
    If you have the existing loom, then it should be quite straightforward. I replaced a 3.9V8 with an HS2.8 (a development of the 300 Tdi) and had to amalgamate the V8 wiring loom with a 300Tdi one. The main issue for me was in working out the layout of the loom and it took quite some time and a couple of tryout fittings to get it right. I stripped both looms and amalgamated the essential wires into a new loom. I don't like leaving redundant wires hanging around.
    2013 D4 expedition equipped
    1966 Army workshop trailer
    Bracken Ridge, Qld
    Hi
    regards
    Have you attacked this job yet?
    gone
    1993 Defender 110 ute "Doris"
    1996 Discovery 1
    current
