Results 1 to 4 of 4
Thread: Removing the autobox output seal
    Mar 2020
    Replacing my transfer case after I ran it out of oil and noticed a few drops of atf coming out around the automatic gearbox output shaft. How do I remove it so I get the new one in, I've only seen the seal pullers that work when there's no shaft in the hole?
    Avoca Beach
    One way is to drill a small hole in the steel ring and put a self tapper in then pull on the self tapper.
    But usually with other similar shafts , you can still get a seal remover in next to the shaft.
    Regards PhilipA
    Apr 2012
    Whyalla, SA
    Or….. small punch and pry once through.
    Mar 2020
    Thanks for the help, all sorted and going back together now
