I conducted a few searches and I found various kerb weights between 1870kg and 2050kg and GVM between 2850kg and 3050kg.
It is interesting that a few sites show the 200tdi with a lower kerb weight and greater GVM but show the 300tdi with higher kerb weight and lower GVM.
The differences in kerb weight could be due to different definitions of kerb weight. eg: no fuel and no driver versus full tank of fuel and 75kg driver. I believe Australia uses the later definition. Towing was consistent at 3500kg.
1990 Land Rover Defender 110 2.5 TDi (107 Hp) | Technical specs, data, fuel consumption, Dimensions: 1990 Land Rover Defender 110 2.5 TDi (107 Hp) | Technical specs, data, fuel consumption, Dimensions
What is the curb weight, 1990 Land Rover Defender 110 2.5 TDi (107 Hp)? 1872 kg 4127.05 lbs.
What is the gross weight, 1990 Land Rover Defender 110 2.5 TDi (107 Hp)? 3050 kg 6724.1 lbs.
1995 Land Rover Defender 110 2.5 TDi (113 Hp) | Technical specs, data, fuel consumption, Dimensions: 1995 Land Rover Defender 110 2.5 TDi (113 Hp) | Technical specs, data, fuel consumption, Dimensions
What is the curb weight, 1995 Land Rover Defender 110 2.5 TDi (113 Hp)? 2055 kg 4530.5 lbs.
What is the gross weight, 1995 Land Rover Defender 110 2.5 TDi (113 Hp)? 2850 kg 6283.17 lbs.
