Results 1 to 10 of 12
Thread: Experience with aftermarket alternators
    Jun 2010
    Buderim
    Has anyone had any experience with any of the cheaper aftermarket TD5 alternators on ebay? It would only be a backup for remote area travel where it would be at least 5 hours to get back to a place where I could get the original alternator repaired(possibly) - or order and wait for a denso replacement.
    Alternatively I good buy a second hand unit and overhaul it as a backup - Has anyone had their alternator overhauled - as I see on this forum that it is mostly toyota parts. What was the cost?
    Thanks.
    1998 D1 in showroom condition, 1999 D2 TD5 with everything, 2000 P38 showroom condition.
    Freelander 2 2012
    1992 RRC sold and now pranged.
    Apr 2012
    Whyalla, SA
    Just service your alternator.
    All these heavy spares are responsible for more failures than the prevention of failure.
    Aug 2010
    Sunbury, VIC
    Alternators are very reliable - if you have doubts about yours, have your local Auto Elect stick new bearings and brushes in it and throw a new reg on it and maybe keep the old regulator as a spare. Parts wouldn't be expensive for this and it only takes 1/2 hour to rebuild an alternator - easy DIY job as well if you're handy with the tools and nothing really to be scared of.
    Remember as well that if you're out bush you'll likely have a solar panel with you - that would keep your battery topped up enough to keep driving should your alternator fail if you strapped it to the roof and didn't run anything but the engine.
    Jun 2013
    Universe A
    I have not had good luck with aftermarket td5 alternators.
    Jun 2010
    Buderim
    Thanks for info. Sounds like I should just take it out and refurbish it with high quality parts.
    Does the vacuum pump ever fail?
    Freelander 2 2012
    Jun 2013
    Universe A
    Quote Originally Posted by peter51 View Post
    It seems rare, but the oil seal can let go, but again, rare-ish.
    Quote Originally Posted by Homestar View Post
    Years ago the alt light came on in my POS at Horsham en route to Adelaide for a meeting.
    No biggy.......... battery just running the ignition, kept going.
    Couple of nights in the hotel, valet fired it up and off I went to get new brushes soldered in at an auto elec place. $10.
    Try doing that in a D4 or a 322 .
    These days I carry a spare brush cage (screw in) around with me in the tool box with a spare new regulator (another story, non RRC).
    DL
    99.87 MB
    They're a massive pain to change on the side of the road. If you're changing it, I would put in something reliable like a new factory or OEM one.
    Slunnie
    Mar 2018
    Perth (near Malaga)
    "Is this a job you want to do twice?". If it's no real hassle, then yeah perhaps a "30% of the price, unknown quality" might be worth a go, but if it's a job you *really* only want to do once....
    Apr 2016
    Country Vic.
    Only difficult part I found with it was the removal of the vacc pump/vac line. Obviously needs to be taken off the pump to get it out to get the new one in.
    On mine, the hard part is taking the line off the outlet .. just won't budge!
    So, only way to get alternator out for me is to remove pump or slice line to get it off and purchase a new line too.
    In terms of "hard to remove alternators", I found it's one of the easier ones.
    Try a v6 Rodeo/Frontera! ... haha ... on the side of the road.
    Arthur.
    '03 D2 Td5 Auto
    '03 D2a Td5 Auto
