I fitted this one
Alpine CDE-173EBT USB Bluetooth CD Head Unit | Automotive Superstore
works fine. Best improvement I made for sound in my 130 was moving the rear speakers up to ear level.
Hi All,
I need to replace the head unit in my 2014 Puma - Bluetooth no longer works!
I have a few queries;
1. I can replace like for like - no problem there but I dont need a CD player so would look at a different (but name brand) unit as they are all retty cheap
2. Is there any point in spending too much on a better unit? I'll keep the existing speakers and won't install an amp
3. If I go for a head unit with DAB, do I need to install an antenna / receiver?
Current unit is this one: Amazon.com: Alpine CDE133BT / CDE-133BT / CDE-133BT CD Receiver with Advanced Bluetooth Wireless Technology : Electronics
I fitted this one
Slightly convoluted answer...
I fitted an Alpine CDE-163 to my car, a MY10 110. To do that, I had to fit an ISO-to-Alpine adaptor lead, as the standard plug was ISO, and Alpine have their own plug convention.
If your car had a factory Alpine, I would guess that it has had "the change", and that there's a good chance another Alpine unit should be plug and play.
Have a look at Home | Aerpro - might help figure it out.
I went through a whole self inflicted drama with mine not long after I got the truck. The unit in the Pumas has special firmware that cannot be upgraded and different features such as Long wave radio that aren't applicable. Alpine Australia couldn't unblock it and ended up sending me a replacement service exchange unit at a reasonable price.If I was doing it again I'd just buy the latest compatible head unit
Alpine CDE-133BT headunit firmware update
A bit more on this post What did you do to your Puma today?
Plugs on the Alpine units should be the same so it should be plug and play (but make sure you check) My Bluetooth was always unreliable on the original unit which is why I attempted to upgrade it. The replacement one has been fine.
Regards,
Tote
Mud do an adaptor to go from Defender to ISO:
Defender ISO Wiring Adapters – MUD-UK
The standard aerial works fine with DAB but you will need a splitter. I used this one:
Signal Master AM/FM/DAB 12V Band Splitter 10db Gain
Jon
