Results 1 to 10 of 14
Thread: Running weight
    May 2003
    On The Road
    Running weight
    I took the RRS over a public weighbridge just before leaving Kingaroy, Running weight
    What a porker !
    2732 with a full tank,,,. wtf,,,,,
    Apr 2012
    Whyalla, SA
    Look at the size of it and the stuff in it.
    Hardly a problem Running weight
    Apr 2010
    Gosford, NSW
    compliance plate?
    I was looking through the brochures etc for the (on paper) weight of my SDV6, and found it to be 2115kg, with GCM 6500 and I saw on the rego paper that the Tare weight is 2052kg, but no GCM or GVM on the rego paper. So I thought I would take a look at the compliance plate, but I cannot seem to locate it..... anyone else found the location of their compliance plate?
    Apr 2012
    Whyalla, SA
    Quote Originally Posted by Gregz View Post
    Not inside the door (bottom of b pillar)?
    Apr 2010
    Gosford, NSW
    Here is the inside of the door pillar. I see a 'sticker' that could be a compliance plate of sorts. Is that it these days? I was expecting to see something metal with rivets.... maybe times have changed.
    Apr 2019
    Koojan WA (part time Perth)
    Plastic, the revolutionary multipurpose material that can be use (and abused) in all sorts of mannerRunning weight
    You would be correct there Gregz, no more stamped aluminium plates drilled and riveted on, tamper proof stickers nowadaysRunning weightRunning weight
    1985 110 Dual Cab 4.6 R380 ARB Lockers (currently NIS due to roof kissing road)
    1985 110 Station Wagon 3.5 LT85 (unmolested blank canvas)
    Nov 2013
    Wollongong
    Spec sheet says 2440 kgs . I assume this is empty , so fuel add 100kg and then wheels if change , mine I reckon an extra 40 k , so 2600 . Will be interesting to get the weight sorted before I hook the van up.
    Apr 2012
    Whyalla, SA
    Quote Originally Posted by Bails View Post
    Don’t trust the spec sheet, options change everything.
    Weight usually includes WET, fuel and 75kg driver for LR.
    Nov 2013
    Wollongong
    What a porker !
    Got 2.8 on mine with full fuel and 2 people.
    Apr 2010
    Gosford, NSW
    so, between what you expected and what you got there's about 200kg worth of marketing spin. heavy stuff, if only it could be removed.
