Would help if you told us which year & model S1 you have they are different.
Gentlemen,
Could someone help me out with an image or directions to how the two throttle return springs are mounted and set up on the throttle mechanism?
The image from the Parts Manual (attached) is not much help, the WorkShop manual provides no information and a search using the parts number only tell me that there springs are 130mm in length, but not where they go from and to.
I'll greatly appreciated any guidance at all.
regards
Jeff in Perth
My apologies, she is a 1953 S1 80"
Arrow end hooks into small hole at bottom of bell crank lever 231289 on the inlet manifold.
Thanks, that is huge help.
regards to you both for being so helpful.
Jeff
