Results 1 to 6 of 6
Thread: TD5 knocking noise with ignition on but engine off
    DylanTD5 Guest
    I’ve searched and couldn’t find anything.
    When I turn my ignition on, but not start the engine, I get a knocking noise from the engine bay. Sounds like someone is tapping a hammer on the firewall, and will do it 20-25 times in about 10 seconds. Happened every time I switch the ignition on, even if it’s only just been turned off.
    I’ve only had the car for a few days so it may be normal, but it definitely didn’t happen when I test drove/drove it home.
    Jan 2011
    Gippsland
    Quote Originally Posted by DylanTD5 View Post
    In my experience ( 11 years ownership & 220,000kms driven in that time ) it is not normal. However with the ignition switch in the position that you describe the fuel pump will be running to build up pressure in the fuel lines and pressure regulator so the only thing that I can think to look for is a ‘loose’ or unsecured fuel line - and is that even a feasible cause for what you are hearing ? I gotta say I absolutely don’t know.
    LROCV member #131
    1999 build D2 TD5 Auto, Mantec snorkel, 2" LRA spring lift, ARB on board air, Ashcroft ATB, CMM air ram CDL shifter, swag & gold pans ....
    Avoca Beach
    I have a couple of suggestions.
    1 The heater blower fan has something in it and is knocking until gaining speed. I had a ball point pen drop into mine via the demister vent.
    2 even though it is not that loud the aircon heat sampler on the RH of the steering column can block up with fluff.
    3 the fuel pump goes for several seconds before engine start. I cannot think of anything in the engine bay that makes a noise with ignition on before start up.
    Has it got a second battery and relay controller?
    Regards PhilipA
    DylanTD5 Guest
    Thanks for the suggestions, I’ll check them out tomorrow morning.
    It has a second battery with DCDC charger, but it makes the noise with that disconnected. My Nanocom arrived today and it’s not throwing any fault codes, and drives fine.
    darwin
    also check the aircon clutch although it shouldnt come in until after the engine starts but sometimes they can clunk.
    Darwin
    03 disco 2a td5
    93 tdi disco [gone to a better home]
    2003 d2a v8 retired hurt
    1988 k100rs bmw gone
    85 county izuzu [gone to a better home]
    69 series 2a [gone to a better home]
    series 2a [gunnado]
    series 3 [gunnado]
    and the tinny
    DylanTD5 Guest
    Problem solved, it was the air con door servos for the vent settings. One guide/metal track had popped off and jammed against another one, the clicking was one of the servos trying to turn them to the correct position.
    Another plus, my aircon blows much stronger now that air can actually be directed into the top vents.
