Results 1 to 10 of 31
Thread: Defender bonnet tyre mount
    May 2008
    Bundaberg Qld
    MoveLater2 Defender bonnet tyre mount
    Anyone know what thread and pitch the hold bolts on the bonnet for the spare wheel are ?. Contemplating putting my spare back there and need to run a clearing tap down them The threads are a little weather beaten to say the least.
    TIA
    As far as I am aware, bonnet mount for Defenders has never been sold (or at least) approved in Australia. This being the case the mount you has most likely been designed for or copied from a Series mount, and as such is most likely 9/16" BSF.
    May 2008
    Bundaberg Qld
    My 92 has the ( pictured) mounts from factory. Inc's 130 also has them. I tried a 12mm as well as a 1/2" UNF and they both ( just) start but I would prefer to run the correct tap down them first.
    I tried the one from my 2A and it is way to big.
    Sep 2012
    Westlake ,brisbane
    Thought you would have had a thread gauge Paul.
    Nov 2008
    Mostly over there
    22.04 MB
    My 84 110 has a similar mount but the lock pin goes through a wheel nut hole not through the centre.
    By memory I replaced the bolts a few years back from my metric collection if that helps. Cannot find my thread gauge due to a shed rearrangement that is incomplete.
    Sep 2010
    Moe, Victoria
    M12 x 1.75
    Oct 2007
    Wantabadgery, N.S.W.
    My '97 130 has a bonnet mount and was delivered new to NSW NPWS before I got hold of it.
    Don.
    Looks like I am learning!
    Another 97 Def 110 with bonnet mount.
    May 2008
    Bundaberg Qld
    Quote Originally Posted by towe0609 View Post
    M12 x 1.75
    Yep, tankuverimuch
