Results 1 to 10 of 16
Thread: Home printer question
    May 2008
    Bundaberg Qld
    Chasing opinions and recommendations for a home printer. Currently have a couple of cheaper Canon printers but having driver issues. Main use is for Nan's scrapbooking stuff with a couple of customer invoices a week from me.
    Both of us run W10 on Lenovo laptops (if that makes any difference).
    TIA
    Jul 2009
    Hobart
    Hi,
    I went to my local Laser Toner Recharge shop and asked their advice for the needs I outlined to them.
    They recommended one of the HP 3 in 1 models and I am very happy with it.
    May 2017
    N/A
    General rule is:
    Cheap to buy printer = expensive ink
    More expensive printer = proportionally cheaper ink
    My laser printer's cartridges are a couple of hundred dollars a set, but they do claim about 60,000 pages per cartridge.
    Arapiles
    2014 D4 HSE
    Oct 2013
    Richmond, NSW
    Quote Originally Posted by pop058 View Post
    TIA
    I have Lenovo/Thinkpad with an HP Officejet 3 in 1 printer. Had no issues until the latest major Win 10 release which seamed to stuff up scanning over WiFi. Can still print no problems but no matter what I do I can not get the scanner to work over the WiFi. Just have to plug the cable in which is inconvenient but doable.
    Shopping around you will often find replacement cartridges (and HP keep changing the software so you have to use OEM unless you have disabled the auto update function) on sale at Officeworks or Big W.
    Travelrover
    Adventure before Dementia
    2012 Puma 90 - Black
    1999 Td5 110 Ute - White
    1996 Tdi 300 Wagon - White
    May 2006
    Ulverstone,TAS
    After years of having canon printers failing after I didnt have to print anything for a month or 2, I finally
    went and bought an Epsom ET 4750. eco-tank.
    Its brilliant.
    You can see the level of ink you have ( havent tried to refill it yet lol)
    Prints,scans and you also get timely updates for the soft/hardware.Plus the prints are good.
    Its a bit pricey when you buy it, but the savings will be in the ink you dont have to keep buying at exhorbant prices and the thing not
    working after sitting for a bit not doing anything.
    Have a look at it when you go have a look at the different models and what they offer.
    DG
    2014 Freelander SE TD4
    2003 Range Rover TD6
    92 disco tdi manual sold
    95 disco tdi auto gone
    Mar 2007
    Canada
    I got an HP Laserjet Pro M479 a short while back and it is great. Fast, double side printing, and long toner life.
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    any of the brother colour inkjet multifunction units are fine for that sort of work and are cheap to run compared to many
    the epson eco tanks are good as well... just bought one to replace my worn out brother.. bit pricier but worth it in the long run... you need to carefully check which model does what tho...
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Quote Originally Posted by incisor View Post
    Can vouch for the brothers. Have had a MFC 260 for years now (scan, fax, print) which has been faultless.
    Only downside now is that the (non genuine) ink will dry up if it doesn't get used for colour printing often, but I don't need to do that these days.
    Also have a small brother laser b&w printer that takes aftermarket toner and drums which is also faultless.
    DL
    Feb 2010
    TIA
    If colour is not needed I think laser printers are the cheapest to run and no issues with ink stuffing up over time.
    If you were local I'd give you one. A lot of places like my business change all as needed even if a few are still working fine. The toner cartridges seen expensive but last for many thousand pages. You can refill them as well a few time. Gum tree and similar or ask the practice manager of your Doc if they have a few they might like to give away
    Brother HL 5040 or even HL 1440 are both out of date yet work horses+++
    The newer ones are wireless. A new "Brother HL-L2350DW Compact Monochrome Laser Printer with automatic 2-sided printing and wireless connectivity, 30ppm, Wifi Direct, Wireless"Is just $159 from kogan $50 or below or a older one with free being a good price.
    Above is of no use if Colour is wanted
    Avoca Beach
    I have an Epson XP235 which cost AFAIR $60 and has been great for several years. It is a wireless printer and will print from my network.
    I use Ebay cartridges which work well with no problems other than a grumble from the printer every now and then threatening dire results.
    They cost about $15 for a set of all colours.
    My only regret was not paying another $10 to get Iprint which I thought I would never use, but lo and behold some months ago my wife said "Can I print my messages from my Iphone?"
    It is also pretty slow , but colour rendition is good even with fake ink, even with photos.
    All I need for non business purposes and it has printed thousands of pages when my wife was President of a Club, and I was also President of a club.
    Regards PhilipA
