I can't answer the actual question, but if I remember correctly, on these engines you can actually see the camshaft and the cam followers, since you have the side cover off. If you turn the engine until one inlet valve has the cam follower directly opposite the peak of the cam, that valve is in the correct position to adjust. From there, the rest of the same type of valve (inlet or exhaust) will be half a turn on the crank to the next one in the firing order (1-3-4-2) since there are four cylinders and the engine is a four stroke. Repeat for the other type of valve.
