Results 1 to 10 of 13
Thread: D3 spun bearings video
    May 2015
    Williamstown, Victoria
    Build date 11th Oct 2003
    LROCV #1410
    Mar 2018
    Perth (near Malaga)
    In the vid, bearings have spun, he says something like the block has spread as he takes out the centre caps over the offending mains and then he's just going to line bore it?
    The next vid will be interesting. Great stuff.
    DL
    St Helena,Melbourne
    4.28 MB
    I am amazed that the bearings don't have tabs that locate in a notch to stop them from rotating, every motor I have pulled down has then.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Jul 2012
    Toogoom, QLD
    she is at least rather cute and amusing. Funny little quips.
    Jul 2013
    They are really only for assembly and do bugger all in preventing a spun bearing. The bore itself should be providing enough friction to prevent the rotation if the sizings are correct. Dont under estimate the power of friction - I've worked on turbines in the 2-5gigawatt power range and the drive couplings are simply friction fit taper - there is no drive keyways, splines etc
    Shane
    2005 D3 TDV6 loaded to the brim with 4 kids!
    http://www.aulro.com/afvb/members-rides/220914-too-many-defender-write-ups-here-time-d3.html
    St Helena,Melbourne
    4.28 MB
    Quote Originally Posted by shanegtr View Post
    I disagree, the tabs are on opposite sides and prevent them from spinning 100%, sure they aid in assembly but will also prevent them moving.
    1974 VW Kombi bus
    Mar 2016
    My ex-Porsche GT3 had friction fit cam gears onto the cams. The power of friction didn’t help me though. During a high speed driver training event where the task was to drive with your feet flat on the floor and not touch the pedals whilst turning a corner at speed (skid pan) and maintaining within the line (learning how to let the wheel move loosely under hand and follow the undulations to avoid skipping the surface), I spun.
    The engine actually ran backwards (yes this IS possible), popped the intake apart (runners connected by rubber joiners between sections) and unbeknownst to me at the time, had shifted a cam gear out of position/alignment. Not enough to cause damage, but enough that the next time I had an MOT I couldn’t pass the emissions test. £3500 later and the engine removed and Porsche Germany involved, they worked out that was what had happened and why it wouldn’t meet emissions.
    Anyhow, I digressed!
    2007 Audi RS4 (B7)
    Nov 2018
    Hobart, Tasmania
    Yes, but you mention a slight taper which is totally different to the crankshaft bearing/shells simply placed into the block and 'hope' they won't spin. I firmly have always felt that not having the locator tabs is the principal reason of the failures.
    As you'd be aware large drill bits are tapered and that taper is the only thing that prevents turning whilst drilling the hole.
    Before: Ser 2a LWB, Ser 3 S/W, 1979 RR 2 door, 1981 LR Stage 1 V8 (new), 1985 LR 110 V8 County (new), 2009 RRS TDV8
    Now: MY13 D4 TDV6. "E" rear diff. Cambo's magic Engine & Auto Tune. 1968 Austin 1800 Mk1 auto (my 5th)
    And to keep the oil holes in the shells lined up with the same in the block so the oil pump can send oil from the sump through the crank to the big end conrod bearings, etc.
    DL
