Results 1 to 10 of 18
Thread: Flexible Panel Advice
    Mar 2016
    Adelaide
    Looking at upgrading the solar that’s currently on the roof of my camper.
    We don’t use much electricity (lights are all LED, adventure kings 60lt fridge, 12v charging ports, gas kitchen). We plan on getting a 3000w inverter in the future (kettle and toaster on windy days). We have 2x 120ah non lithium batteries.
    Are these panels ok? I was thinking of getting 2 of them to allow for rain/grey or shaded campsites. I know there’s a formula for calculating panel output according to size.
    Also, is this supplier ok? Has anyone had any bad experiences?
    VoltX 240W Flexible Solar Panel Shingled Solar Module | Outbax
    "Land Rover - making mechanics out of everyday motorists for nearly 70 years"
    Apr 2019
    I have no experience with the panels you have posted but for those dollars for the size Id question the quality. I learnt this lesson.
    I’m on my second set of semi flex panels…….keep I mind you don’t get as many watts per square meter with semi flex when compared to fixed panels.
    First set were cheap…..and didn’t last Flexible Panel Advice . It didn’t help that we stored them under the bed at the beginning which meant they were being flex every time we pulled them out than stored them. They eventually went onto the roof but deteriorated quickly. I learnt that semi flex only like to be flex once into the one position than secured, if you want them as portable I’d personally go a blanket or two, more suited to the application.
    Second set have been awesome, been on for 2+ years. No longer available Flexible Panel Advice Below was there performance on the weekend just gone, sitting flat on the roof on a day that had clouds constantly moving overhead. 224w from 2 x 120w panels was pretty good on an average day.
    I’m now deciding which semi flex to buy for our trip, 3 x 120w….o need them to have eyelets in them.
    I reckon I’ll buy 3 of these from Jason…..
    120W AllSpark Flexible Solar Panel
    May 2006
    Woolgoolga
    To me, flexible and solar don't work, thats just from being a sparkie and working in the solar industry
    Apr 2019
    Quote Originally Posted by Vern View Post
    What doesn’t work about them?…….there’s lot out there than throw in blankets on top.
    My current one are working fine based on my application.
    Apart from loosing out another with watts per square meter mine perform pretty close to stated specs. I don’t see that I’d get a whole lot of better performance if I mounted traditional panels to my roof, given I’m trying to keep weight down.
    Mar 2016
    Adelaide
    I do agree with you, but I’m using a scissor lift pop top camper that doesn’t have 12v actuators to lift the roof. So putting 20-40kg of solar on the roof is out of the question. I have thought about putting in 12v actuators, but not just yet.
    May 2006
    Woolgoolga
    Quote Originally Posted by W&KO View Post
    Personally i don't think they should be bendable is what i meant. Seeing the damage caused with fixed panels from people standing on them or mishandling them, the cells just don't hack it.
    But i suppose you're not trying to get 10+ years out of them.
    May 2006
    Woolgoolga
    Quote Originally Posted by John_D4 View Post
    What would your maximum weight allowance be??
    Apr 2019
    Cools, yes we learnt not to constantly bend the cheap one we had first time round hence I recommended OP to consider blankets.
    No chance of standing on our, especially when roof is raised.
    Apr 2012
    Whyalla, SA
    I’ve had those flexible 120w units..
    I’ve had 4 sets of 4 units - eg replaced them 4 times
    I now have 2 Victron rigid panels at 130w each and do better and without the hassles of them crazing, cracking or just failing.
    Mar 2016
    Adelaide
    Not really sure. At the moment I need to lie on the bed and bench press it up. Lighter is better in this scenario. After you raise it a certain height the springs on the scissor lift will take over and lift the roof the rest of the way.
    TUFF TRACK ESCAPE / Far Horizon Campers
    (Oh my goodness, that price has jumped by $10,000 in 3 years. Gotta love the Covid tax)
