Results 1 to 9 of 9
Thread: Td5 engine mounts
    Feb 2013
    Queensland
    Td5 engine mounts
    Hi all how difficult is it to change engine mounts on a td5 mine are shot and need doing I would prefer to do it myself if the job isn't to involved.
    Thanks Phil
    North Central Victoria
    Easy as mate. I did my old bus in a few hours. Just be careful jacking from the sump.
    All you need is a trolley jack and a few lengths of 2 X 4.
    Jan 2014
    Perth Western Australia
    What he said...plus
    Buy genuine or you will be doing them again
    Daz
    Feb 2013
    Queensland
    Do you have to unhook radiator and intercooler hoses
    Quote Originally Posted by laney View Post
    I didn't. And the advice on genuine mounts is spot on Td5 engine mounts
    Apr 2016
    Country Vic.
    I was under the impression that the td5 passenger side mount is quite difficult to remove/refit due to space constraints.
    Not impossible to do, just more harder than the drivers side.
    Arthur.
    '03 D2 Td5 Auto
    '03 D2a Td5 Auto
    May 2015
    Williamstown, Victoria
    What he said, and use genuine. There is a howto some where.
    BUT!
    From what I remember, do not follow rave, undo the bolts, a 500mm extension is handy.
    Jack up the engine, block of wood to protect the sump.
    Here we go
    Replacing D2 TD5 engine mounts - how to.
    Build date 11th Oct 2003
    LROCV #1410
    Mar 2011
    Balbarrup WA
    Re jacking TD5 to chnage mounts
    Quote Originally Posted by Bohica View Post
    BUT!
    Here we go
    When I jacked my engine up I also undid the two small mounting bolts that hold the coolant crossover pipe in under the radiator, as the hoses were looking a bit stretched as I jacked.
    However they can be fiddly to refit back in afterwards.
    Sep 2010
    The Hills.
    152.79 MB
    Quote Originally Posted by DazzaTD5 View Post
    What he said...plus
    Get 'em from Mario
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
