Further to the above I found the following, dated 2016 on the Patrol forum.
Mine has 4The old ones (10 years) had a two field motor (count the big torx bolts around motor housing; 2 @ 180 degrees = very bad, 4 @ 90 degrees = very good) and the two field job would burn out the armature if you gave it a dirty look. Those ones also had this appalling spiral spring brake that would live up to its name and break very easily. The newer ones have 4 field better quality motors (still not as good as XD9000 motor) and normal warn brake (very good).![]()
