Results 1 to 10 of 18
Thread: Emergency Home Lighting When Power Fails
    I have been looking for a light that I can plug into a standard home power point that comes on when there is a power failure.
    These Click Nightguard lights seem to fit the requirement Click Nightguard Mini Rechargeable Nightlight - Bunnings Australia
    I dont need the motion sensor function, just need a light that comes on when the power goes off - also dont want to do any wiring - just plug in and go.
    Unfortunately, the Click Nightguard does not get very good reviews - the motion sensor function is poor but I dont need this. The other problem is the charging mechanism burns out after a short time which is not good.
    So does anyone know of another product that simply plugs into a standard 3 pin household socket and comes on when power goes off. As I said not interested in anything that requires wiring in etc.
    St Helena,Melbourne
    4.28 MB
    How often do you think you'll need it, easier just to keep a few torches handy.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    May 2021
    Mackay
    You could use emergency lighting as used in commercial premises down to kids lamps that come on when the room goes dark
    Queensland
    I usually have my iPhone on me or close, or have an iPad handy.
    These make for great emergency lighting when needed.
    Yass NSW
    I have an Aldi trouble light that sits in a charger cradle, if you leave it turned on when charge is present it does not illuminate but when the charger cradle is powered off it comes on automatically. I haven't seen them at Aldi for a few years but maybe something that is a possibility. I can't see whether this one has the smarts to come on automatically Narva |
    'See Ezy' Rechargeable LED Inspection Light
    Regards,
    Tote
    Jun 2008
    The new Gold Coast, after ocean rises,Queensland
    you. could do something with an emergency exit light.
    not an attractive item but they last for donkeys years.
    not cheap as far as I know but I doubt you could do better
    Are these available off the shelf with a standard plug fitted?
    Aaron
    Oct 2008
    Cloncurry NWQ
    Generator, battery, windmill, hurricane lamp?
    2 sticks?
    Jun 2008
    Quote Originally Posted by Aaron IIA View Post
    Aaron
    available off shelf , but instead of wiring it into your lighting circuit you could wire a 3 pin plug into it instead.
    I can wire in a lead and 3 pin plug into an appliance that is designed for fixed wiring, or a licensed electrician can?
    Aaron
