Results 1 to 10 of 26
Thread: SRS light
    Sep 2010
    The Hills.
    152.79 MB
    SRS light
    Car is inching its way towards a RWC and now the bloody SRS light, which was on some time ago but has been off for months, has decided to reappear... sigh. SRS light ON, RWC Off. Cleaned and checked all the under seat and console connectors to no avail. So a quick guess, is it the clock spring? Horn and cruise work fine.
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    Jan 2017
    Geraldton WA
    Have you checked the relay?
    It's in the engine bay fusebox
    4.6m Quintrex boat
    Oct 2020
    FNQ
    Quote Originally Posted by Tins View Post
    the cluster is very easy to separate and insert some black electrical tape over the SLS LED.
    Ask me how I know (cough ABS light, same RWC situation)
    Also just try disabling the SLS option with nanocom.
    You'll have to fix it anyway, so kinda moot ideas. Just saying.
    EDIT OOPS read srs as sls. Dont mess with that
    Sep 2010
    The Hills.
    152.79 MB
    Quote Originally Posted by trout1105 View Post
    The yellow one?
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
    Sep 2010
    The Hills.
    152.79 MB
    Quote Originally Posted by Discosux View Post
    Funny, but that was suggested by a certain mech....
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
    Jan 2017
    Geraldton WA
    Disregard what I said I read it as SLS Not SRS.
    Maybe an OBD2 unit May clear the fault (these only work on the V8 D2's) otherwise you may have to get your airbags serviced.
    4.6m Quintrex boat
    Sep 2010
    The Hills.
    152.79 MB
    Well, I have a Nanocom coming. Again.
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
    99.87 MB
    Its probably the just plug under the front seats. It's not so uncommon. Give them a jiggle or reconnect and it will probably sort the light.
    Slunnie
    Sep 2010
    The Hills.
    152.79 MB
    Thanks, but I've tried that a few times.
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
    May 2015
    Williamstown, Victoria
    Try jumping across the yellow plug. That may turn of the light.
    If you need to remove the plug, remove the jumps first. The yellow plug is special and will close the contacts on the cables to the squib. You do not want a nasty little EM pulse setting the squib off!
    Build date 11th Oct 2003
    LROCV #1410
