Results 1 to 10 of 11
Thread: Wiring for Discovery 4 2015
    Nov 2021
    Team
    fitted a front bar and manage to pick up fog lights as used old fog light wiring
    now need to pick up indicators left and right and also park lights left and right side
    as there is a multi plug at the head light connection
    can somebody guide me with the various colours for wires I need to spline into to get the indicators and park lights in the bar working
    appreciate your help
    thanks
    Hennie
    BradC is online now Super Moderator
    No one of consequence
    Supporter
    Mar 2018
    Perth (near Malaga)
    According to the wiring diagram :
    Left : Park / side - RB (Red Brown - Pin 2) / Indicator GR (Green Red - Pin 3)
    Right : Park / side - RO (Red Orange - Pin 2) / Indicator GW (Green White - Pin 3)
    Nov 2021
    Brad
    thanks a million I will get into this soon and update you on the outcome
    Hennie
    Apr 2012
    Whyalla, SA
    Just remember - Strip and solder... Do not use scotchlocks...
    Supporter
    Mar 2018
    Perth (near Malaga)
    I pop the pin out of the connector, strip a bit of insulation with a blade, solder and then slide some glue lined heatshrink on. Much neater and less destructive than the old snip, twist and solder.
    Apr 2012
    Whyalla, SA
    Quote Originally Posted by BradC View Post
    That’s how I do it too. I never cut the wire.
    Just pointing out the avoidance of Scotchlocks.
    Supporter
    Mar 2018
    Perth (near Malaga)
    That should be written in fire above the door of every establishment that sells them.
    On the other hand, you'd be shocked at the number of people who've never heard of glue lined heatshrink, or that you can de-pin a connector. So it's all about awareness. Friends don't let friends use any insulation piercing connectors near a vehicle.
    Nov 2021
    Dear all
    i am back after a few days breaking out of the daily routine
    indeed fantastic advice
    Can I push my luck asking if somebody can guide me on where you locate a detailed guide of wiring layout for the headlamp wiring on both left and right side
    reason as want to wire spots as well and need to pick up the bright for contact to relay
    however I believe you need to be able to operate the spots with or without the brights
    brights with spots or spots only
    anybody done a spot and bar light setup / wiring recently
    Hennie
    Apr 2012
    Whyalla, SA
    You can get the manual from the Aulro shop on CD or electronic download.
    You must wire Driving lights to use the high beam trigger, and it must then be separately switched.
    Giving you the following choice:
    Low beam
    High beam
    High beam & Driving lights
    Supporter
    Mar 2018
    Perth (near Malaga)
    You can find an early D4 wiring diagram here (where I got the colour code info from) :
    Later D3 wiring diagrams
