Simple stuff first rotate tyres and see what happens.
Hi all
Have read all posts I can find and a bit confusing to me trying to find the same symptoms.
Bad vibration
Really appreciate some help
disco 3 Auto 190,000km
No offroad work and no hard driving.
Tyres 90% front / 30% rear
I feel this a drive line rather than tyre issue.
The vibration is pretty bad throughout the cab. I have a feeling it is not from the rear but around the transfer area or towards the front.
The vibration seems to run in something like a 1sec cycle as a unijoint would with old style uni's
Float or very light throttle = vibration
very slight road curve = vibration slightly worse
Throttle off = vibration gone
Accelerate = vibration gone
Have jacked up each wheel. Felt play by hand in all joints.
Front shafts = very slight play inner joint equal both sides
Centre bearing = no movement
Centre rubber bush = visually ok and can be moved slightly by hand.
I am looking for somewhere to start in diagnosing this issue.
cheers to all Devo
 Master
						Master
						My experience leads me to say it is the transmission ,
Unhappily , two solutions, put up with it, or new auto.
Forward drive shaft? Check all CV boots.
 Master
						Subscriber
						Master
						SubscriberLock up clutch in the torque converter
It doesn't leak oil, Its sweating power
Sounds like rear prop shaft and/or bearing to me. Easy to check and would be my first port of call before looking at something more exotic.
2013 D4 expedition equipped
1966 Army workshop trailer
