Thread: It is the thermostat TD5
    May 2015
    Williamstown, Victoria
    The coolant temp gets to 69C. Even after a 25km drive.
    I replaced this three years ago, I think with a genuine.
    Other ideas? Options? Does running out of coolant bugger them up? Three years seems a short life to me.
    Build date 11th Oct 2003
    LROCV #1410
    Back down the hill.
    Are you sure it's not the sensor? I recently changed my 'stat because, intermittently the gauge wouldn't come up to temp.. I still occasionally see the same issue, so suspecting a dodgy sender.
    Avoca Beach
    Pull the sensor plug off and on a few times and or spray it with some electronics cleaner.
    This low temp thing happened to me and luckily I tried that first.
    regards Philip A
    May 2015
    I did think of cleaning the sensor, and testing the temp with a IR thermometer. More fun for tonight.
    LROCV #1410
    May 2015
    regards Philip A
    I tried to remove it at work, I couldn't push the clip in enough. It moved maybe 2mm. That was enough, temp gauge back to normal. Win win.
    LROCV #1410
