Can't see how it would be possible since you can't upgrade the air springs or shocks.
 Master
						Supporter
						Master
						SupporterJust curious.
Can you do an Axle-Sum GVM upgrade on a D4?
Standard GVM = 3240
Front axle = 1450
Rear Axle = 1855
Axle-Sum = 3305.
Yes, yes, I understand about zero flexibility but was just wondering is such a thing was possible. I realise it only gives you 65kg increase of GVM if allowed so probably barely worth it, if it could be done. Just wondering.
2014 SDV6 SE, Fuji White, ARB bar, Fyrlyt 5000, Pioneer Platform, Traxide D4-5S, Maxxis 980 Bravo, GOE Compressor Plate, ICom-450 UHF, Red Arc Tow Pro.
Elite Murray 2 Caravan 24'4" Tare-2917kg, ATM-3500kg
2004 Jayco Freedom tin tent
1998 Triumph Daytona T595
1974 VW Kombi bus
1958 Holden FC special sedan
Maybe try these guys (link below). They provide suspension components for the up-armoured Land Rovers used by security and bodyguard type organisations, so should be able to give you an idea of what's possible at any rate.
Parts for Land Rover, Range Rover, Mini, Jaguar & Tesla
Life is just a series of obstacles preventing you from taking a nap.
 Master
						Supporter
						Master
						SupporterI wasn't thinking of upgrading any components. It's just that yesterday I came across some Youtube clips of people that upgraded their GVM to an "Axle-Sum" upgrade. There are also a few websites that discuss this. Whilst I'm aware that it has limited application for a D4 as you would only get 65kg upgraded GVM, because OEM GVM is only marginally below the axle sum.
With other vehicles such as Patrols and LC they have 200-300kg upgrade possible with an Axle Sum upgrade as in their cases the OEM GVM is well below the axle sum. I was just wondering if anyone had heard about it or done this on a D4? Because their is no actual vehicle modification taking place I was curious as to what might be required. Clearly if it's simply a brake test and getting a certifier to do a Mod Plate it might cost a few hundred dollars. Perhaps hardly worth it for only 65kg, but just wondering. I will enquire at at VSCCS Certifier out of interest. Just thought someone on here may have already done so.
Gotcha - no mods! The protection detail vehicles are much heavier than standard so need upgraded components, which aren't cheap.
 Master
						Supporter
						Master
						SupporterI spoke to an VCSSC Certifier today to find out what was the go. Nice guy and explained situation. Firstly, an Axle-Sum GVM upgrade is available to any vehicle, HOWEVER, there has to be some form of modification to the vehicle that can justify it. With a LC for instance all they might need is upgraded springs or shocks or add airbags to justify a axle-sum GVM increase. Obviously, with a LC if enough stuff is changed they might be able to get a GVM increase that also increases each axles load rating.
With the D4 the options of making any change to the suspension are limited to non-existent, so there is little that you could do to get an axle-sum GVM upgrade. There might be something that you could do but not worth it for only 65kg increase in GVM.
FWIW, the armoured D4 version has a GVM of 4050kg straight from the factory. If it was affordable (and legal), I would love to do the upgrades to be able to carry the extra weight (~800kg), but leave out the ballistic protection of course. It might drive like a pig though...
Land Rover Introduces Powerful New Discovery 4 Armoured Vehicle | Land Rover Media Newsroom
 Wizard
						Subscriber
						Wizard
						SubscriberAs the vehicle will be able to carry more weight, better brakes would be needed. So fit a set of updated rotors (Which makes sense when you need to replace the rotors as general maintenance), there is your modification to justify the axle-sum increase.
Bear in mind I am not qualified to backup my theory on this being a way to qualify for the increase.
2014, MY14 Discovery TDV6, Fuji White (2018-Now)
2003, Discovery 2a, Td5 Manual, Zambezi Silver (2012-2018)
2007, Adventure Offroad Campers, Grand Tourer (2015-Now)
 Master
						Supporter
						Master
						SupporterNext time I'm in Orange I will visit the certifier to find out what changes to brakes and or shocks (for example) might be enough to justify a GVM increase. I'm not sure how long the shocks last for but I'm sure after a couple of hundred thousand they might get spongy? I have no idea what exact modifications are done on suspension for the "Heavy Duty" D4, However, if all they have for the suspension is different shocks for example you might be able to get more than an axle-sum GVM upgrade. I'm not after anything ridiculous, but if you could get 200kg upgrade in GVM with simply upgrading a few components at regular maintenance time, it might be viable?
