Results 1 to 9 of 9
Thread: Instal DRLs
    Instal DRLs
    I am going to replace the headlight lenses/covers on my 2007 RRS as they have severe UV damage and have internal cracks in the polycarbonate. While I have the headlight assembly apart I thought I wouldn't mind fitting DRLs around each of the lights (basically the same as a D3 headlamp).
    Researching I have come across various sized halo rings etc but I would prefer a dedicated kit to fit the lights.
    So anyone know of such a kit and can provide a link. Yes I know I can put DRLs into the fog lamps but I dont want to go that route.
    No one put DRLs into the headlamps of their D3/RRS?
    Jul 2009
    Mid North Coast, NSW
    51.4 KB
    not yet, was actually wondering if its a setting that is in nanocom etc ?
    Quote Originally Posted by haydent View Post
    Before you can nonocom anything, you need to have DRLs fitted.
    Jul 2009
    51.4 KB
    what are you fitting ? (link) what i thought might have been a native option was to just use the parking lights, but maybe not bright enough. ?
    Parking lights are not suitable. As I indicated, when I find a suitable product that people have used, I am looking at installing a ring kit into the headlights. I have a couple of links from the Uk site and will look further after Christmas.
    4 x Range Rover Sport Vogue Discovery headlamp led smd rings drl 120mm 2 cob | eBay
    Jul 2009
    51.4 KB
    ok, does it get wired into anything factory and config changed ? or you just going to wire to acc circuit ?
    I will just wire it in like any other car with the appropriate relay/s - no config needed.
    DRL Daytime Running Light Relay Harness Auto Car Control On/Off Switch | eBay
    Jul 2009
    51.4 KB
    why you need a kit ??
    also where did you get the clear lenses from ?
    im interested in doing this, was it hard to take the lights apart ? did you have to take them out of the car ?
