Results 1 to 10 of 26
Thread: A trip to the test centre
    Ireland
    Though this concerns a series 111 I posted it here as it covers a number of things.
    I was back up today with the 1982 series 111 2.25 diesel 88" wheel base, for a retest as she failed first time on a number of things. It involves an 80 mile round trip. On the way up I had to make two emergency type stops because of wasps emerging from the heater vents! Bit of a shock when the first one decided to make it's presence known. Anyway I managed to get it out of the driver's door. A short time later the second one made it's presence known and involved another quick stop and fumbling at the passenger door. Probably hibernating and being unceremoniously dumped out into the cold December day probably did not do their temperament any good.
    One of the issues the series 111 failed on was movement in the lower bushings on the front shocks. No problem just put new ones in I hear you say. Well that is what the mechanic did but there was still the same slight movement (LR bushings) in the shocks. I think this is how they are. The only way to solve this was to put top bushings from rear shock absorber of a defender into the series 111 front shock absorber. Completely different bushing but it worked. To my mind it is too good a fit as there is no play what so ever but it kept the tester happy.
    The other issue was a braking imbalance in the front axle (8%). I could not understand this as she was braking steadily and in a straight line. Anyway the mechanic stripped everything out and reassembled both sides using a torque wrench to ensure everything was even. The inspector passed it today but said the brakes were a bit odd but the sheet showed the imbalance was within limits.
    I think that expecting a 39 year old vehicle to be as efficient in a test as the newer stuff is asking a bit much.
    Having taken the series 111 and parked it ready for the inspection he then took charge of a MAN tractor unit and 40 foot trailer. He managed to turn the MAN tractor unit and trailer in a smaller space than he did the series 111. Also judging by his facial expressions with a lot less effort too! It seems the gearbox on the MAN was easier to use too .
    Anyway that is the 88 sorted for another two years. As she is over 30 years of age the test is every two years. Vehicles pre 1980 do not have to be tested. And as she is 30 plus years of age she costs me the princely sum of €56 (88.90 AUD) to tax yearly. Insurance is for a vintage vehicle which is cheap too. (30 years of age gets you vintage tax on a road vehicle)
    P.S. While waiting for the 88 to be tested I stood outside well wrapped up and wearing a mask. Not so long ago if you were seen to be loitering outside a premises wearing a mask the police would have been called.
    Nov 2008
    Mostly over there
    22.04 MB
    I agree with you when you state "I think that expecting a 39 year old vehicle to be as efficient in a test as the newer stuff is asking a bit much." as I see it here too when a young tester jumps into the old '84 110 truck and tries to figure out how to start it, let alone test it. Our local testing centre I use has a couple of old army mechanics who have 110 experience so I like it when these guys get to give my old 110 a once-over.
    The periods in your testing regime is interesting. Here in NZ it works the other way around. Here it is a warrent of fitness (WoF) certificate.
    If your vehicle is:
    • less than 2 years old, the WoF will be issued up to the third anniversary of when it was first registered
    • between 2 and 3 years old, the WoF will be issued for 12 months.
    You have to get a warrant of fitness check every:
    • 12 months if your vehicle was first registered anywhere in the world on or after 1 January 2000
    • 6 months if your vehicle was first registered anywhere in the world before 1 January 2000.
    Ireland
    Over her passenger/private registered vehicles no test until year four. Every two years until they reach ten years of age then yearly.
    Commercially registered vehicles yearly from day one.
    Vintage (30 years onwards) every two years unless used for commercial purposes then still yearly.
    I had a tester who had to bring me into the testing lane as he did not know how to turn off the series 111.
    Nov 2014
    Nirvana near Albany W.A.
    Quote Originally Posted by windsock View Post
    Here I was, thinking over here was hobbled by nonsensical bureaucracy, but I see we have a way to go yet.
    Nov 2008
    Mostly over there
    22.04 MB
    Quote Originally Posted by discorevy View Post
    Yes, presents a six-monthly dose of WoF anxiety and sometimes repair bills. Key payback is the assumed/implied high quality road-worthiness of the old vehicle fleet on our roads, which I understand is quite high in percentage compared to other countries. I say assumed/implied as many differences can be noted in the quality and efficacy of inspections between testing stations. Some are quite lax while others are straight up and test to the legal list. I usually go to an independent tester not affiliated or involved in repairs and they usually appreciate my well maintained old 110.
    If I had to get my truck inspected every 6 months it would sextuple the frequency it would have been driven over the last few years. Good thing we don't have anything like that here, I would be going to the testing station nearly every month.
    Aaron
    Back down the hill.
    Spud, requirements for inspection, in this country, vary between jurisdictions. Some have annual safety checks, whilst others only mandate certification at change of ownership.
    Statistics indicate that mechanical failure rarely have a significant contribution to cause of collision. Further, states requiring annual checks fare no better than the other states in comparison, with mechanical issues contributing to incidents.
    Conclusion, inspections serve no useful purpose.
    Ireland
    Some years ago I had two inspections done on the one vehicle in the one day. This was an administration mess up computer wise. First one in the morning and the second a few hours later in the afternoon. The read out for braking efficiency, suspension imbalance etc DIFFERED in the two tests, Same vehicle, same testing equipment, Go figure,,,
    Mar 2018
    Perth (near Malaga)
    And at least one other has no testing unless you're caught doing a burnout in front of a plod and cop a canary. My 33 year old Volvo hasn't seen the pits _ever_. Just paid the rego yearly and don't get caught doing dumb stuff.
    Some of the ****boxes we have tootling around WA are total and utter deathtraps.
    Back down the hill.
    Here we have an annual blitz on roadside mechanical inspections for heavy vehicles, despite them being inspected yearly, in every state.
    Defects are classified and published. Some trucks/trailers have eight or more stop lights (minimum two required), depending on the level of bling the owner desires. Should just one of the multiple brake lights fail at inspection, it is classified as a serious brake defect.
    Fear mongering to garner public support for government employees overtime bonanza.
