Page 1 of 5 123 ... LastLast
Results 1 to 10 of 43
Thread: Another Case of Production Design not Communicating with Mainenance Design
    Mar 2010
    Queensland
    12.97 MB
    Hello All,
    A couple of days ago I broke the transmission belt on my ride-on mower. The V-belt runs between three pulleys. When I bought the new belt I was informed by the salesperson that I would have to loosen the differential/transmission bolts that hold it to the chassis. Well, I tried that technique and I had to take it one step further. The diff had to come off and the mower chassis jacked-up. By twisting the diff one way and the chassis the other enough room became available to fit the V-belt to the large pulley that connects to the transmission.
    It is obvious that on the production line the V-belt is fitted to the pulley that has already been mounted to the transmission. The transmission with the belt fitted is then bolted to the chassis. Away it goes to the next stage of the line.
    When the belt breaks there is not enough room between the outside diameter of the pulley and the vertical side of the chassis to fit the new belt. Neither is there an access slot cut into the side of the chassis. No, the undercarriage has to be disassembled and twisted to fit a new belt in. Another great example of a lack of communication between the production and the maintenance design people. I suppose by the time the belt breaks it is someone else's problem and the sales money is already in the company's bank.
    Kind regards
    Lionel
    Sep 2010
    The Hills.
    152.79 MB
    Quote Originally Posted by Lionelgee;[URL="tel:3122889"
    3122889[/URL]]Hello All,
    Kind regards
    Lionel
    I didn’t know LR made garden equipment.
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    Back down the hill.
    I doubt any manufacturer has a maintenance design department. They do have engineers design the product life, that if the engineers get it right, fail just out of warranty.
    Brisbane,some of the time.
    Quote Originally Posted by Tins View Post
    I am sure many on here would be glad they dont
    Wasn't there an equally complicated problem if the clutch cable broke in a VW Beetle?
    Mar 2012
    Armstrong Creek, Qld
    In the 70s, my accommodation was a government caravan. These were built like the proverbial outhouse, by a company who had never made 'vans previously, but won the tender. Ahem!
    Anyway, whilst working out the back of Woop, the 'van fridge decided to cease operation. On contacting my boss, the bloke that shared the van with me and I were instructed to remove the fridge, for return to Brissie for repairs.
    We went to the exterior side of the 'van, only to find a small air vent. No removal there. After a bit of fiddling around, we managed to get the fridge out of its hole in the cupboard and free standing. Tried getting it out the door, to no avail. We took vital dimensions and realised it was a futile battle. Next option was the roof hatch. Nuh, same issue as the door.
    On relaying this to our boss, after some research, he found out that the 'vans were built with everything internal in situ and then the walls and roof shell lowered into position from the top!
    There was no way that fridge was coming out until we could get the van back to the manufacturers. Which we did, but it meant life in a tent for my mate and I for quite a while.
    'sit bonum tempora volvunt'
    Jan 2014
    Perth Western Australia
    Quote Originally Posted by Lionelgee View Post
    Hello All,
    Kind regards
    Lionel
    Let me guess... its a John Deere ?
    Daz
    Mar 2010
    Queensland
    12.97 MB
    Quote Originally Posted by DazzaTD5 View Post
    G'day Dazza,
    Sorry Dazza no coconut for you - It is an MTD.
    Kind regards
    Lionel
    Back in the day,changing the fan belt on a Series 1 with a Capstan winch wasnt the greatest job either....
    Mar 2010
    Queensland
    12.97 MB
    Hello All,
    Well after getting a time consuming task out of the way I was able to return to the mower. I had taken the mower's model and serial number to the specialist mower parts place and they handed over a replacement belt.
    After I dropped the transmission/differential from the chassis so I could fit the new belt and reassembled everything I thought that the belt looked very slack. The reassembly to the point of the mower being able to run and drive - without completing all the aesthetic parts had an underwhelming result - the belt slipped.
    So, I went online and typed in the brand of the mower and its model and serial number. I found the part number for the replacement belt. I checked the pack that the replacement belt came in. The replacement belt had a different number to the parts book. I checked to see if the number from the parts manual had been superseded with a new parts number - nope. I was given the wrong sized replacement belt.
    Did I mention how I took a printed page with the model and serial number on it to a specialist mower parts place?
    Now I have to take the damn transmission/diff off just to retrieve the belt so I can take it back and get the right sized one - bugger! I have already added the right part number to a new copy of the page with the model and serial numbers I had previously given them. Not like I will be paid anything for doing the job that they are paid to do properly - you know the word 'professional'
    Kind regards
    Lionel
