Results 1 to 4 of 4
Thread: RR 2008 3.6 TDI Oil in Cooling System
    Bagel01 Guest
    Hi All,
    I have a 2008 RR Vogue 3.6 TDI, that has oil in the cooling system, bought it this way, dismantled by a shrek.
    I was told the cause was the oil cooler.
    I have no reason to believe or not believe this diagnosis. I have attached a photo of the oil cooler mounting face which shows some pitting on the mounting face which may be the cause or is it possible that there has been a internal failure of the oil cooler.
    My Questions are,
    1. Where do i source a rave manual and is that the recommended Manual ?.
    2. Can you buy the rubber gaskets that mount the cooler to the base plate or can you only buy the complete unit Base plate with mounted oil cooler, approx $ AUS1,500 plus freight from England.
    3. Has anyone had a failure with 3.6 tdi oil cooler causing oil within the cooling system.
    Any advice that could help would be greatly appreciated
    Thanks inIMG_0322.jpgIMG_0323.jpg Advance.
    Brett
    Aug 2008
    Perth, WA
    37.36 MB
    Hi Brett. I can help with #1 as you can purchase a RAVE manual from the 'SHOP' button on top of this page (link below). Can't help with #2 or #3 though, but I'm sure someone will be along shortly to help with those.
    RR_P38a_L322
    Life is just a series of obstacles preventing you from taking a nap.
    Brisbane, Queensland
    Hi Brett
    Don Radkey in Toowoomba owns a L322 3.6 so knows his way around these motors, and has 1 or 2 at his workshop for spares. He might be able to help. Phone no below.
    +61 7 4637 2250
    He just replaced all my coolant hoses and thermostat housing.
    L322 tdv8 poverty pack - wow
    Track Trailer ARN 200-117
    REMLR # 137
    Bagel01 Guest
    Hi rar101 and cripesamighty,
    Thank you for this information, will buy the manual i know i need it. I will contact Don and see what he thinks about this Dead Range Rover.
    Thanks again.
    Brett
