Page 1 of 13 12311 ... LastLast
Results 1 to 10 of 123
Thread: Can anyone identify this tapping noise?
    Gladstone Qld
    Hi All,
    Just wondering if anyone can identify this new tapping noise that has appeared on my 2007 RRS 2.7 TDV6?
    Doesn't sound real good to me!
    IMG_1937_MOV_SparkVideo.mp4IMG_1936_MOV_SparkVideo.mp4
    Jun 2013
    Universe A
    It doesn't sound good! But I can't diagnose that from the video, maybe someone else can....but I would not be starting it again until it's been checked by a workshop that knows that particular model motor.
    St Helena,Melbourne
    1.13 MB
    Could be numerous things but mine sounded like that when one of the injectors wasn't seated/sealed correctly after replacing the copper washers.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    May 2014
    Point Cook, VIC
    Jun 2013
    Augusta WA
    I wish I hadn't listened to those! The OP sounds like the top end to me.
    MY09 D3 TDV6 Zermatt Silver
    MY02 TD5 Bonatti Grey (Sold)
    MY00 TD5 520K (Sold)
    Gladstone Qld
    Quote Originally Posted by shack View Post
    Thanks Shack,
    I live up in Gladstone QLD so they are hard to find!!
    Gladstone Qld
    Thanks again Disco DB, Sounds more like the last one that was unresolved to me.
    Gladstone Qld
    Cheers loanrangie,
    I'll check the injectors.
    Gladstone Qld
    I've put the same on the Range Rover forum, just to add Disco DB and my response-
    Originally Posted by DiscoDB
    So at this stage I would not do any more test runs until you work out what it is (let people listen to your video if they want to hear it). If it is a spun bearing this will lead to a snapped crank. Although sadly the cost to rectify either case will be the same, but at least one outcome is rebuildable.
    I personally would pull out the oil filter, cut it open (so I could expand it fully) and look for metals bits between the accordion. You can also get an oil sample analysed to confirm it is (or isn’t) a bearing failure.
    When you remove the oil filter, look to see if it had a crushed spigot due to not being fitted properly.
    That is planning for the worse. Hopefully though it is something a lot simpler and cheaper to fix, and someone will pipe in with a much more optimistic theory.
    Thanks DiscoDB,
    I have removed the Oil filter and it looks all good, no crushed spigot. I have drained the oil (looks good) and removed the oil sump to check. I found about 6 small flakes that looked a copper colour? but no other metal shavings etc. I'll do the filter chop tomorrow.
    I haven't had it for long and the previous owner replaced the engine due to the old oil pump housing failure with a low klm engine
    that had 50,000 k's on it, now its about 69,000 k's. Would be very unlucky to replace it again!! I've always looked after it and replaced the oil twice in the year I've had it. Fingers crossed.
    I'll suss out getting the oil sampled.
    Cheers mate much appreciated.
    Gladstone Qld
    Would anyone know a good LR mechanic in QLD that could help me with this?
    I don't mind putting it on a trailer and going the distance!
