Originally Posted by
haydent
this came back several times, and went away with skimming, so decided the pad must still not be retracting fully on one side, (which did appear to have noticeable more dust buildup on rim) , or there is something soft about discs (less likely)
so i put on new pads and discs, and second hand callipers, so far hasnt come back
Different car, but my Volvo 740 was prone to a shudder under braking. A new set of front bushes ($50 and half an hour) fixed it for a while till they were shagged out again. It turned out to be a sticky caliper. A good dismantle, clean, new seals and it was good until I sold it. It did take me 2 years and 3 sets of bushes before I actually fixed it.
Uneven braking load on a front end can cause all sorts of issues that look like (or cause) something else. Now, If I'd had the forethought to go for a long drive and put the IR thermometer on each disc, I'd have picked it up earlier. The caliper at fault resulted in a noticeably warmer disc on that side. Not cooking enough to smell, but about 25% warmer.
