Results 1 to 10 of 19
Thread: Restricted Performance and GAP IIDTool Faults
    Mar 2017
    A month ago, I got the dreaded Restricted Performance fault up on the dash display. It seemed a good idea to get a GAP IIDTool to help me to find out the cause before I spent hard-earned $$$ on repairs. I bought the tool, it has been delivered and activated and now I don't know what it all means. After clearing all faults, the following fault reappeared:
    U1A24-87 (28) MOST ring complete, no communication - Bus signal/message failure - missing a message.
    At 202656 km Triggered on 14-11-2021
    This sounds to me like a loose wire or bad electrical connection. Any ideas of where to start looking would be appreciated.
    Apr 2012
    Whyalla, SA
    MOST bus is the audio system
    Mar 2017
    Ok, so the MOST is associated with the audio system. From what I have read in the GAP Tool manual, U faults are generally able to be cleared and ignored unless persistent. I've still got the restricted performance and red warning light up on the dash display, but no other ECU faults. That seems to be illogical to me.
    Jun 2020
    in the the advanced settings of the faults - add in pending faults and see what pops up.
    Mar 2017
    OK. So Christmas has intervened in my diagnostic efforts. My D4 battery was getting low so I charged it up and noted that the Restricted Performance and RED waring light was still up with ignition on.
    Now the GAP Tool was telling me:
    PCM - Engine Diesel 3.0 L HSCAN - 1 fault
    P010D-00 (AF) Mass or volume air flow B-circuit high
    At 202656 14-12-2021
    So I thought that if I swapped the MAF sensors and the fault goes to A then it is a faulty B sensor. Easy. Not so easy... With a bit of fiddling with the looms, I managed to swap the connectors. I noticed that the forward sensor incorporated a temperature sensor. So any fault there could be ignored.
    After swapping the sensor connectors, started the engine and got No Faults on the GAP Tool. So I swapped the connectors back and went for a drive around the block (about 5 minutes). The Restricted Performance was no longer showing, but the Red Warning indicator was still on and the engine felt sluggish (like no turbos).
    I remembered to re-read this thread and on the GAP went for Advanced faults pending and got the following:
    P010B-22 (64) Mass or volume air flow B circuit - range/performance - General Signal failure - signal amplitude&gt: maximum
    At 202659 km
    Triggered on 09-01-2022 14:47:26
    P010D-00 (27) Mass or volume air flow B - circuit high
    At 202659 km
    Triggered on 09-01-2022 13:44:34
    I can't see any oil escaping from the engine, so it is unlikely to be a manifold (the RH manifold was replaced not long ago). Can it be a faulty MAF sensor or is there more investigating to be done?
    Mar 2016
    Quote Originally Posted by StewG View Post
    At 202659 km
    At 202659 km
    Have you enabled Pending Faults under advanced? I would expect to see a P006a fault with that which is a volumetric mismatch between MAF and MAP. I say this based on you swapping the MAF and still it says the B sensor. I had this two, I swapped MAF, was still there, then found the pending fault. It was an intake leak.
    2007 Audi RS4 (B7)
    Mar 2017
    Quote Originally Posted by DiscoJeffster View Post
    I did enable the Advanced > Pending faults, but I had already swapped the sensors back. I'm going to have to do the whole exercise again to see if B fault changes to A fault.
    Apart from two trips around the block, I've barely driven the car in many months and both the D4 and my caravan are a spiders' paradise - covered in cobwebs...
    Mar 2016
    It may be the MAF then. Swap them, then see if the fault goes until the second turbo kicks in. After that, if confirmed, try a MAF cleaner before you buy a new one.
    2007 Audi RS4 (B7)
    Mar 2017
    Over the past few days, I have been fiddling with the MAF sensors, including cleaning with CRC MAF Sensor Cleaner (it made no difference). The attached pdf (if I get it attached ) shows GAP Tool screen shots and explanations. I'm still at a loss to know exactly what the problem is although I have seen a small amount of oil on the LH intake manifold and hope that it is not cracked. The RH side was replaced about two years ago when I first got "Restricted Performance" and that set me back about $1600.
    Attached Files Attached Files
    Mar 2016
    Put a piece of white paper on top of the manifold and put the cover back on. Go for a drive, nail it, then check for soot on the paper. Easy test. Do the same on top of the throttle body/y piece. Mine split there too.
    2007 Audi RS4 (B7)
