How to erase yellow warning lights?
					Hi Folks,
My two yellow lights concerning the brake fluid/low level came on. The front disc pads still had around 20% remaining and the sensor wire had not chafed thru due to worn pads. However I replaced front pads and topped up the fluid reservoir but I can't get the yellow triangle and the yellow brake warning light off. Also, the message that my brake pads are worn still appears, but I can press "ok" and it goes.
I didn't refit the brake sensor wire 'cos it was brittle and it broke and I didn't have a spare, so I taped it out of the way. I wouldn't think that is my problem as it is not "live" until earthed out due to wear by the brake disc pad. (Am I correct??).
No fault codes showing.
Have checked the reservoir float and seems ok.
Is there a special way of re-setting the system so the yellow lights disappear?
MY13 D4 TDV6
Thanks,
				Before: Ser 2a LWB, Ser 3 S/W, 1979 RR 2 door, 1981 LR Stage 1 V8 (new), 1985 LR 110 V8 County (new), 2009 RRS TDV8
Now: MY13 D4 TDV6. "E" rear diff. Cambo's magic Engine & Auto Tune. 1968 Austin 1800 Mk1 auto (my 5th)
