Results 1 to 3 of 3
Thread: Are Oils Oils?
    May 2003
    On The Road
    Are Oils Oils?
    CASTROL EDGE PROFESSIONAL C1 5W-30
    so if I am in Upperkumbuctawest and the thing is at the low mark,,,
    is there a common alternative?
    I will, at the next service, ensure I buy a couple of litres to put aside..
    but thats not for another 6-7 thousand kays..
    (I plan on doing 12K changes,, IF it will do that, its two marks down after 5K
    I dont mind the usage, it works pretty hard for its keep..)
    Apr 2012
    Whyalla, SA
    If it’s chewing oil - that’s not acceptable.
    It doesn’t work any harder than thousand of those that aren’t burning oil.
    Did you follow the guidelines for bedding in the vehicle? No towing before a certain number of kilometres etc?
    Apr 2012
    Whyalla, SA
    As a top up - any C1 oil, then change asap.
    And get it checked - burning oil shouldn’t be happening.
