Results 1 to 10 of 19
Thread: An aid to fueling up
    Ireland
    I was filling up the Puma in the shed today. The filling side was in the shadow as the overhead light was above the Puma. I was holding a little torch to see when the diesel hit the required amount. I thought wouldn't it be useful if manufacturers put a little LED in the fuel filler recess that would let you see how near to the neck the fuel was. Just a thought. How about it Mr Ineos for the Grenadier?
    Wodonga
    Quote Originally Posted by spudfan View Post
    You dont really need it as the petrol pump hand pieces, have an automatic stop when the nozzle is covered by liquid.
    Mar 2012
    Armstrong Creek, Qld
    Quote Originally Posted by gruntfuttock View Post
    Not in my shed, they don't.
    'sit bonum tempora volvunt'
    Ireland
    Quote Originally Posted by Saitch View Post
    Same as mine, thus the idea.....
    Wodonga
    I dont think that having an electric wire/connection near a fuelling point would pass the safety check.
    Wodonga
    Why don't you install a light in the proper place in the shed so as you can see what you are doing.
    Ireland
    I usually hold a flash light but as it would, the battery died! Owing to the space limitations if I installed a wall light I'd be in my own shadow. It is not a big deal but just an idea that came to me.
    Back down the hill.
    Battery not included, nor needed.
    Apr 2012
    Whyalla, SA
    You could always drill a hole in the panel above, fit a flush mount LED in there and a waterproof push button switch.
    If you so desired.
    Nov 2008
    Mostly over there
    22.04 MB
    The Jerrycan torch
    The illuminating funnel
    Luminescent fuel additive
