Thread: L322 Off-road (Sand) Experience
    Jan 2022
    who has had experience driving a L322 on Australian sand beaches. How capable is the vehicle?
    Nov 2019
    About as capable as any other 4x4 with lockers/good traction control. It’s more so about technique and tyre size/pressures though.
    05 L322 Range Rover | BMW M62 4.4 | Cairns Blue
    07 Lexus GS450h | 2GR-FSE Hybrid | Blue Onyx Pearl
    NSW SW Slopes
    Not beach sand, but my MY12 with its CVDs was exceptionally good on the chopped-up / dug-out approaches to the sand ridges on Googs track where its tyres always had good ground pressure, albeit with the suspension raised 30mm.
    Brisbane,some of the time.
    Lower tyre pressures,i usually go to 25 PSI to start with,then down to 18 in the soft stuff.
    Make sure stability control is off,and be carefull as it comes on each time the engine is started.
    If it isnt off,you will get stuck,guaranteed.
    i always take a long handled shovel,and have snatch straps,shackles,etc.
    Raise suspension if needed,momentum is your friend,good luck with it all.
    Oct 2007
    Brisbane West
    Quote Originally Posted by LoxGold View Post
    What diameter wheels are you running? She is a heavy beast so low pressures, offroad height and momentum, gearing (low range where possible) and centre diff locked (should do automatically shouldnt it?) would be the go (i imagine). Cheers
    Nov 2019
    Here's me driving my 05 L322 (model without the terrain selector) on the beach for over an hour. All raw footage. Pretty sure it was at 18psi, 275/65/R18 AT's.
    Beach Driving 4k | Australia 🇦🇺 | Noosa North Shore to Rainbow Beach - YouTube
    Sep 2010
    The Hills.
    152.79 MB
    Not sand, but I guess you'd say they're pretty capable.
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    Queensland
    I did a few trips to North Stradbroke without issue - 285/50’s at 18psi; a Member here towed a van across the Simpson with his 3.6TDV8….(!) so probably enough there to say “very good on sand” !!!
    L405, Vogue SE, 4.4SDV8, 8 speed, Rear e-diff
    Brisbane, Queensland
    Ive taken my 2008 tdv8 L322 to Straddy, Bribie, Moreton and Fraser several times using both 19” & 18” tyres. Ive only got stuck once briefly at the bottom end of Straddie as forgot to turn off DSC, coming off the beach. After a clearing sand away from wheels i reversed out, and went again this time with DSC off.
    It’s pretty easy in a L322.
    Also, Llams to set EAS height would be good to have (have since fitted one) to help ensure momentum isn’t lost from bottoming out.
    L322 tdv8 poverty pack - wow
    Track Trailer ARN 200-117
    REMLR # 137
    Queensland
    Hi Lox, I took my 02 L322 to Fraser Is in 2006 and other than letting my standard road tyres down to 18 and raise the height, I did not change any setting and I had no problems keeping up and going where other 4x4s went, and that was ALL sand driving.
