Results 1 to 6 of 6
Thread: Servicing Records
    Oct 2011
    Fremantle WA
    Servicing Records
    Under the assumption that owners (as opposed to registered service agents/providers) cannot access the full maintenance information stored in the LR Online Servicing History data base, has anyone done up a paper based service requirements for d4s as we used to get with the D2 etc?
    Jan 2020
    McGowanastan
    Quote Originally Posted by gavinwibrow View Post
    Do you mean something like this
    Cheers Bulletman
    Dec 2009
    Baldivis WA
    Go here Land Rover
    Put your VIN in
    Select ‘Servicing information’
    Select required service from the ‘Service type’ drop down menu
    Click ‘Print’
    Job done.
    This only works for MY13(?) or newer, it definitely works for MY14.
    2014, MY14 Discovery TDV6, Fuji White (2018-Now)
    2003, Discovery 2a, Td5 Manual, Zambezi Silver (2012-2018)
    2007, Adventure Offroad Campers, Grand Tourer (2015-Now)
    Feb 2021
    Quote Originally Posted by kelvo View Post
    Go here Land Rover
    Put your VIN in
    Click ‘Print’
    Job done.
    Thank you kelvo - worked a treat. Seems strange to me that neither the 48 (84k on odometer) or 60 (93k) or 72 month service sheets show any outstanding issues or recommended extra work yet, especially as it as 102k at the last service.
    Oct 2011
    Fremantle WA
    Quote Originally Posted by Sandy View Post
    Thanks to kelvo and I have downloaded the schedules for my poverty pack 2016 D4 and put them into a spreadsheet.
    The LR info only goes to 10 years at 26K km pa - which in my case for normal running around will be changed to 10K km and given my nanna driving style and not too many short trips I've extended to a max of 9 months or 10K km, whichever comes first.
    Apart from a very few "check" mentions, there is virtually no provision for what we would call preventative maintenance for a number of known items.
    I'm going to list the ones I know of here and happy for others I've missed or don't know about to be added. When done I'll make it available for anyone interested.
    Listed by LR
    Renew ancillary driving belts each 10 years/260K km
    Renew camshaft drive belt and tensioner each 7 years/182K km
    Renew the automatic transmission oil and filter. (recommended extra) at each 5 years/130K km.
    Others for inclusion - feel free to add/correct others including ID/recommended timelines
    Fit new oil pump along with camshaft belts each 7 years
    Suspension Air Compressor/Desiccant
    A/C Compressor
    Radiators & bugs
    Suspension/Control Arms/Airbags (separate line for each?
    Fuel Pumps (HP & LP)
    Water Pump
    Oil Pump
    Power Steering Pump
    Alternator
    "Y" Manifold piece (Alloy billet "Y" piece?)
    Turbos
    "Foam" under top of radiator grill etc
    Underbonnet sound/heat proofing
    Brake Switch
    Rear door actuators - (do mods?)
    Battery/ies
    Fobs
    Oct 2011
    Fremantle WA
    Listed by LR
    A/C Compressor
    Radiators & bugs
    Water Pump
    Oil Pump
    Power Steering Pump
    Alternator
    Turbos
    Brake Switch
    Battery/ies
    Fobs
    "CUT AND PASTE" TYPOS FROM ORIGINAL SPREADSHEET TABLE ERRORS NOW CORRECTED
