 Fossicker
						Fossicker
						Hi guys,
I have the TDV6 D3.
When accelerating away from lights or driving on hot days the fan roars and seems to slow acceleration.
Has anyone replaced the clutch system with an electric system? That way acceleration is not limited by the big fan winding up.
Thoughts?
Cheers!
Rob
It already has electric assistance and they only roar for a few mins if that.
2004 Jayco Freedom tin tent
1998 Triumph Daytona T595
1974 VW Kombi bus
1958 Holden FC special sedan
I for one love the roar.
Would be wicked if I had a little momentary button on the dash to activate, as it makes the whole thing sound so much more butch!
2010 TDV6 3.0L Discovery 4 SE remapped to RRS output, Alaska White, GME XRS-330c, IIDTool BT, Dual Battery, Apple CarPlay, OEM Retrofitted: Cornering lights, Door card lights, Power + Heated Seats, Logic 7 audio
I've noticed that normally the fan only fully locks up when my coolant temp hits 107degC. Until then I never hear it. Normally with no trailer attached my coolant temps never get that high. I'd suggest monitoring your temps (through OBD) and noting when the fan is kicking in as something may not be 100%
Shane
2005 D3 TDV6 loaded to the brim with 4 kids!
http://www.aulro.com/afvb/members-rides/220914-too-many-defender-write-ups-here-time-d3.html
A simple electric fan can not move the sheer volume of air that the current offering does.
It will be a big step backwards.
The impression of the fan causing a huge slowing of the vehicle is just that, just an impression. The reality is more to do with fuelling strategies during high heat soak.
 Fossicker
						Fossicker
						Thanks guys - jury is in - roar to stay.
It’s true - the roar does draw attention 😆.
Will have a look at a coolant flush and thermostat etc.
It just seems to roar from take-off for a short duration and then settles down quickly.
Cheers!!
 Super Moderator
						Super ModeratorYou can do that, but it won't make any difference. The algorithm that controls the fan relies on a number of different inputs, not just coolant temp. On a warm day in Perth with the AC on it will pretty much do that after any idling at traffic lights. From the Manuel :
"The ECM determines engagement based on the coolant, charge air, ambient and transmission oil temperatures and the A/C pressure."
If I don't want it to roar and it's a stinking hot day, I just sit at the lights with the revs at about ~1500. Makes the A/C work better too!
 Fossicker
						Fossicker
