Results 1 to 10 of 34
Thread: D4 Suspension Problem
    Feb 2016
    Hi
    i have an issue of front passenger side being lower than driver side, around 15mm on average.
    It can be more in the morning.
    After driving it comes up to within 10-15mm difference.
    To me the front looks like it’s sitting low.
    If it was losing air, wouldn’t the whole car drop?
    One suggestion has been a height sensor.
    I did damage one a few years ago and was replaced, massive pot hole.
    I’m wondering if another is faulty also.
    Following the car on the freeway it looks like it is leaning down to front corner.
    Any thoughts would be greatly appreciated.
    Vin
    Cheers Vin
    2025 D350 Defender 110
    NSW SW Slopes
    Leave overnight with the 20A suspension system fuse removed. This will prevent periodic levelling which will then allow a leaking corner to lower by itself. Leaking can be from an air-spring or the corner valve in the valve block.
    Feb 2016
    Thanks Greame
    So you think a sensor, more likely air leak.
    Looking at it today and comparing to other D4s I see around, the whole front is sitting low.
    Very frustrating.
    I think it’s been that way for a while, now that I think about it.
    Vin
    Cheers Vin
    NSW SW Slopes
    An air leak is easy to confirm or rule out and needs to be ruled-out before considering sensor calibration.
    Feb 2016
    Hi
    Last night I measured both sides of car, 4mm difference for the record.
    Pulled the fuse.
    This morning the car had not dropped at all, mm perfect.
    I monitor as I drive it today.
    The front still seems too low compared to back.
    I will compare against friends D4 today.
    Cheers Vin
    Mar 2016
    Quote Originally Posted by rhinosm View Post
    Hi
    Pulled the fuse.
    Take measurements from the wheel arch to the hub centre. Front should be 466mm, rear 485mm. That will tell you if it’s sitting low.
    2007 Audi RS4 (B7)
    Sep 2014
    Baldivis WA
    Re calibrate the height sensors now that you've established there's no leak.
    Feb 2016
    whats involved in Re calibrating sensors?
    vin
    Cheers Vin
    May 2014
    Point Cook, VIC
    Quote Originally Posted by DiscoJeffster View Post
    And unless you are in Tight Tolerance Mode, individual heights can vary by up to 10mm. So it is possible to see a 20mm difference across the front or rear.
    Feb 2016
    So heights front-end rear look good on driver side, 465 & 485
    Passenger side 10mm both front and back.
    Would that be considered normal?
    Vin
    Cheers Vin
