Hi and thanks JayTee, I had not seen that video.
It is the typical Lithium Battery B/S sales pitch.
First and foremost, find a single lead acid battery manufacturer that states their batteries should not be discharged below 50% SoC. They are either 20% or many of the newer AGMs are 0%.
Another point, base on the specs of the Redarc lithium batteries, which are just average, there are far better lithium batteries for a fraction of the price. For example, SolarKing are a fraction of the cost and have better specs.
There is lots more that that video incorrectly covers.
. How the hell does he think a lead acid battery works ? And a 50% discharge limit, what a load of crap. Sure, the deeper you discharge a battery the shorter its life, no surprises there. Personally I use 11.7 volts or around 30% SOC as my max no worries discharge limit for lead acid. IMO re-charging rate is more likely to ruin a deeply discharged lead acid battery than its actual discharge level, slow is good
