Results 1 to 10 of 12
Thread: A/C or no A/C
    99.87 MB
    A/C or no A/C
    ok, this may potentially take the dumbest question award... actually I have had a dumber one in the past if I'm totally honest.
    I have a 95 V8 manual 3dr. I had always been under the impression that it did not have an AC system in it.
    So, tangent, I was fixing an idling problem (turned out to be a perished vac advance hose with a great big hole in it and a blocked port into the plenum), as I was shutting the bonnet I noticed there is an AC compressor. Checked the dash and there is no indication that I could see that the Disco has an AC system in it. Just a fan, heat/cool controls, demist and recirculate.
    Any ideas? Clearly I have something grossly wrong somewhere.
    edit...... that icicle button that I thought was demist.... is that an AC button?
    Slunnie
    Jan 2017
    Geraldton WA
    Looks like one of them buttons on the dash switches the air con on/engages the clutch on the compressor.
    Check to see if you have a faulty relay/fuse
    4.6m Quintrex boat
    Sep 2010
    The Hills.
    152.79 MB
    No such thing as a dumb question. Does that button look like this?downloadice.png
    If so it's the AC button...
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    99.87 MB
    Legends, thanks for this! I always just had in my head that was a demist type function and had never used it. Clearly not a lot of critical thought put into it.
    That is the same label on the button and I'll test it out. If it doesn't work I'll check the fuses etc.
    Thanks again! I feel like this is a bit of a bonus that I never knew I had in the Disco! I hope it works.
    Slunnie
    Apr 2016
    Country Vic.
    also note that AC only works(or engages) when fan is set to run too(at any speed).
    So you may have the snow icon engaged, or pressed in, and fan off .. therefore AC is still off .. just like your image shows.
    Arthur.
    '03 D2 Td5 Auto
    '03 D2a Td5 Auto
    99.87 MB
    Quote Originally Posted by AK83 View Post
    Thanks for this! I've just given it a go. Looks like the AC system works, the switch lights up when operated, compressor engages but it doesn't blow cold - after all of these years it hopefully it just needs a regas with some luck but that may be optimistic.
    Slunnie
    Mar 2018
    Perth (near Malaga)
    If it's a 95 it might still be R12, so may need a conversion.
    If so, get it done properly rather than the "add a little PAG on top of the mineral oil and fill-er up".
    Sep 2010
    The Hills.
    152.79 MB
    I hope it works.
    It's a Disco so that is the real question.
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
    North Central Victoria
    Yep, that's the aircon button. My dash in my 97 is virtually the same. You won't get blown over by the blower motor speed. But if it's sat for a while you can be guaranteed the blower motor will be full of sticks/leaves/twigs. It's the black thing in the passenger foot well. Three posi drives and it comes out. Very easy to do. Just need to be a bit flexible! A/C or no A/C
    Brisbane,some of the time.
    Quote Originally Posted by BradC View Post
    There will be a label under the bonnet somewhere designating what refrigerant is in it and the quantity.
    One of my brothers has a '93 D1,and its R12.
    Its lost its gas a couple of times,the leaks have been the seals around the condenser pipework joints.
    I think around '95/'96 was when they changed to R134a,so as Brad said,could be either.
    I know where there is some R12,but its a long way to go if you want some.
    If you havent missed the AC for all those years,maybe just leave it as is.....
