Results 1 to 6 of 6
Thread: Wiring a dip switch
    Feb 2018
    Adelaide
    Wiring a dip switch
    G'day all,
    I'm wiring up my dip switch, I've got a new loom. Is there any way of knowing which of the connections on the switch are which ? I'm happy there is an earth, high beam and low beam. I assume when the plunger is lowered it creates a contact to points, when it retracts the point rotate to create the circuit to the opposing circuit (low or high beam) but what I don't is which is what on the switch. Does this make sense ? (I'm a complete novice when it comes to auto-electrics)
    The photos attached may help.
    Thanks again
    Sep 2010
    The Hills.
    152.79 MB
    Quote Originally Posted by Kimsl70 View Post
    G'day all,
    Thanks again
    Been a while but I don’t think that any of those terminals will be earth. One will be power and the other two will go to the lamps. The earth should be close to the lamps.
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    Nov 2014
    G'day Kim,
    The headlight dip switch is called a single pole double throw (SPDT) latching press button switch. (There is no earth used on the switch.)
    It switches the negative lead from the battery via the headlight switch to the high and dip headlight bulb. (Assuming you still have a positive earth system.) From the manual the High beam cable is Blue with White tracer and dip is Blue with Red tracer. The common contact is connected to the cable that goes to the headlight switch and connects to either the High beam or Dip beam when the switch is pressed.
    From your picture using YOUR labels the low beam is the common and the high and dip cables can go on either the High or Earth contacts because it is a latching press button switch so it can be either one.
    The best way to confirm the contact positions is using a mutlimeter on low ohms to check continuity.
    Hope this makes sense!
    Chris
    Sep 2010
    The Hills.
    152.79 MB
    Quote Originally Posted by Busted Syncro View Post
    G'day Kim,
    Chris
    Darn. I forgot about +ve earth.
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
    Feb 2018
    Adelaide
    Quote Originally Posted by Tins View Post
    G’day Tins.
    Thanks a lot. I really appreciate the reply. I’ll go out today and have another look at it.
    Cheers.
    Feb 2018
    Adelaide
    G'day Kim,
    Chris
    G’day Chris
    Thanks for reply I really appreciate it. I’m going to go out today and run the multimeter over it. Makes a lot of sense. Thanks again.
    Kim.
