Results 1 to 10 of 26
Thread: But I've got a snorkel...
    Nov 2015
    Black Rock
    This happened walking distance from where I live in inner Melbourne. Insurance response will be interesting!
    Melbourne floods weather: Uber driver stuck in Victorian floodwaters escapes onto bridge (9news.com.au)
    2013 D4 expedition equipped
    1966 Army workshop trailer
    Jun 2008
    The new Gold Coast, after ocean rises,Queensland
    I was going to fit a snorkel to my Ranger.
    I had a chat to my indy about it, who happens to be a Walkinshaw performance affiliate.
    He asked me why and I gave the usual reasons....he suggested I would get no benefit over the standard intake , unless I wanted to take it swimming.
    I don't know if Defenders use same intake , exactly same engine , but many/most Defender owners have a snorkel on their 2.2 puma engines.
    Jan 2017
    Geraldton WA
    The MAIN reason that I fit a snorkle to a 4WD is to access the cleaner air at the top of the vehicle instead of sucking air into the engine from the dusty wheel arches.
    Being able to do the odd water crossings without getting water into the intake is just an added bonus.
    4.6m Quintrex boat
    Brisbane,some of the time.
    Almost all insurance companies have a get out clause which basically says no cover if the vehicle is driven into water.
    It is usually hidden away in their disclosure statement.
    Jun 2008
    what do you call an odd water crossing? 1200mm is only at bonnet opening on the Ranger, I would never contemplate that depth for any reason.
    May 2006
    Woolgoolga
    Quote Originally Posted by ramblingboy42 View Post
    Whats the wading depth?
    Not hard to fall in a hole in a river and very quickly get to that depth.
    Jan 2017
    Geraldton WA
    The depth of the water although an important factor is only one of many considerations I take into account before I even attempt any water crossing.
    The rate of flow is probably the most important thing to assess then you have the amount of traction the bottom will allow, is it salt or fresh water, are there crocks in the water, is it tideal, do I REALY NEED to make the crossing.
    If for ANY reason I think the crossing is risky I won't attempt it.
    1200mm in a ranger and you would most likely just float away downstream.
    I have done 1200mm or maybe a little bit deeper in my fully loaded 79 series on a couple of occasions and there was absolutely no danger of that puppy floating away.
    I wouldnt even try those sort of depths in my D2a.
    4.6m Quintrex boat
    Jun 2008
    I don't know it's wading depth, is there an official wading depth? I'll look at the hand book.
    found this quickly....
    https://www.drive.com.au/news/2012-f...r-takes-a-dip/
    Mar 2012
    Armstrong Creek, Qld
    Quote Originally Posted by trout1105 View Post
    This is 1200mm on my Toyota 'tilly. Either there's a depth perception problem here, or a contradiction in the first and second statements?
    I wait to be corrected, of course.
    'sit bonum tempora volvunt'
    I did bonnet height in my D2a numerous times with no real issues.It had a snorkle.
    I always used a blind across the front and didn’t hit the water too hard.
    The only issue we did have was the horns filled with water and blew a fuse which also disabled the Cruise control.
    If we did get stuck at those depths we would have had issues,the first being a soaked gearbox ECU as it’s fitted in a brilliant place under the passenger seat.
    We did get stuck in a creek near the old crossing of the Jardine one year,and water was just over the rear door sills,the rear of the vehicle was down quite a bit lower than the front. Luckily the gearbox ECU didn’t get wet,but we found hundreds of small fish flapping around in the second row of seats footwell,once we got out.
