Results 1 to 10 of 14
Thread: Fault code
    Feb 2022
    Fault code
    Hi, new to the forum and have just bought a 2008 Discovery 3. Just wondering if anyone can help out, I’ve got a GAP iid tool and keep this message
    B1D21-13 (2F) Remote control switch
    General electrical failure - circuit open
    I keep clearing it and it keeps coming back. I’ve gone through and checked the earth points, checked the transfer case module for corrosion and all looks good. I have just replaced the alternator and the battery is still strong..Every now and then the radio will go off and then come straight back on..Any thoughts? Cheers
    Mar 2018
    Perth (near Malaga)
    Do the steering wheel controls work properly (Audio and Cruise)?
    Feb 2022
    That’s something I’ll check tomorrow, it only has cruise control, no radio controls
    Feb 2022
    Quote Originally Posted by BradC View Post
    Hi, yes the cruise buttons seem to work well, thanks
    Mar 2018
    Perth (near Malaga)
    The reasoning behind my question is every reference I can find to that fault refers to the SWC. The ones closest to that specific fault refer to the stereo, so I wonder if your car thinks there's supposed to be buttons on the wheel and there isn't?
    The threads that show genuine faults all seem to point to the clock spring.
    Feb 2022
    Good thinking, most likely the clock spring causing it, I’ll try clearing the fault and then move the steering wheel around to see if it faults.. The stereo works ok but drops in and out every now and then, I thought that was just a reception issue..
    I’ll let you know how I go
    Feb 2022
    Quote Originally Posted by Dashing View Post
    I tried that and it didn’t fault 🤷*♂️ drove the car for about 30 minutes and the fault is back, probably will change the clock spring at some stage I think
    St Helena,Melbourne
    4.28 MB
    No CCF change required for adding SWC so id be surprised if it faulted for it not being there.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Feb 2022
    That’s true, I checked the CCF today and SWC is disabled. I did find it strange though that Bluetooth was enabled although the car doesn’t have Bluetooth..I disabled the Bluetooth so I’ll see if it faults again tomorrow
    Sep 2014
    Baldivis WA
    You sure it doesn't have BT? I've got the SE spec with the small screen and that has BT.
