There are probably not too many har have fitted lithium to the new defender…….
Although I have an older defer my lithium is in a tight compartment with cupboards surrounding it. There is ventilation via the gap around the cupboard door.
I regularly check the temp of the battery and it’s always been in the green zone, even on hot days. My thoughts are if it’s insulated with stuff over the top and there is a bit of ventilation than all should be good.
Re vibration, you’d be running air all round, I don’t reckon vibration with be an issue. I run half air suspension and half springs for the three years mine has been installed with no issues to date.
In my install the biggest heat generator would probably be the DC-DC……this is mounted above the battery in a cabinet with more ventilation.
