 Fossicker
						Supporter
						Fossicker
						SupporterHi troops! I have a 2007 RRS TDv8, which requires work done on both front and rear diffs.
Would the diffs out of a 2011 3.0 SDV6 RRS be the same as the diffs in mine?
Can anyone recommend a diff mechanic in Melbourne?
Thanks!
2013 D4 expedition equipped
1966 Army workshop trailer
Bearings and seals can be sourced aftermarket. Try Advanced Factors who do kits.
Diff ratios vary depending on the engine so you need to research carefully before buying.
 Fossicker
						Fossicker
						2003 td5 378,000 still using original diffs. Why are rr and 3 and 4 stuffing diffs. Are they really made from rubbish metal. Hard to believe these r supposed to be off road vehicles.
 Fossicker
						Supporter
						Fossicker
						Supporter| Search AULRO.com ONLY! | Search All the Web! |
