Can you just hook on to the cargo barrier mesh itself?
 Fossicker
						Subscriber
						Fossicker
						SubscriberHi All. I have a 2014 Disco 4 TDV6 and have fitted an Autosafe half barrier that replaced the forward cargo tie downs. Now I am looking at installing something to hold down my Dometic Waeco car fridge. Has any body added anything to be able to tie down with these?
 Fossicker
						Subscriber
						Fossicker
						SubscriberI put a draw and kitchen in the back of my D3. These are bolted to carpet covered ply, and the ply is bolted to the tie down points.
I went to the big green shed and got M8 S/S Eye Bolts, took the bolt out of the tie down points and inserted eye bolt. Still have a tie down points.
Edit: at least I think they are M8.
There is no eraser on the pencil of life.
Now - Not a Land Rover (2018 Dmax)
Was - 2008 D3 SE 4.0l V6
Was - 2000 D2 TD5 with much fruit.
Ray
Nothing a piece of bent steel cant fix, show us a pic of the location. Before my drawer setup i used some plywood with slides mounted to it that was bolted into the RH tie downs points.
2004 Jayco Freedom tin tent
1998 Triumph Daytona T595
1974 VW Kombi bus
1958 Holden FC special sedan
 Fossicker
						Subscriber
						Fossicker
						SubscriberThanks guys. I'll try for the M8 SS EYE BOLTS at the big green shed. Didn't realise the bolt down points on the barrier replaced the proprietary points.
Maybe take a bolt out of a rear tie down point and take in as a reference so you get the correct size. Mine were like 80mm long so I just trimmed to suit. Gotta love an angle grinder.
Ray
When I fitted mine many years ago, I was able to refit the tie down points over the barrier mounts just by grinding off the little locating tab on the underside of the tie down point. It was a full height barrier but I would expect the mounts to be the same.
Jon
Not sure what the bolt setup looks like for the barrier but where I needed the front tiedown after I bolted down my fridge slide base over the top of it, I used something like these:
Canyon Dancer Stainless Steel Strap Ring Tie Down Hook Point Single | eBay
PAIR 2PC Motorcycle Trailer Tie Down Tiedown Points Loops Motorbike Scooter | Ne | eBay
Hopefully you can just put the mounting bolt for the barrier straight through them
If you want them flat when you're not using them then this type might be the go: Goliath Lashing Ring Loop - Bunnings Australia
David
Everything is easy when someone else is doing it
MY14 SDV6 SE Corris Grey
Compomotive 18s : D697s : Traxide DBS : LLAMS : ARB compressor : IC-455
Rhino Platform : GOE compressor, Tx & front bash plates, deluxe sliders
 Fossicker
						Subscriber
						Fossicker
						SubscriberHave found these on Amazon. As the existing bolts are M8 25mm these should do nicely.
https://www.amazon.com.au/MySixKeen-Lifting-Stainless-Thread
