Results 1 to 9 of 9
Thread: Trailer wiring
    Mar 2022
    Australia
    Trailer wiring
    Hi everyone, I just purchased a 2011 Range Rover sport, great car but I just noticed that when I put my caravan on the back and hit reverse the sensors go on , I thought that was supposed to cancel the sensors when trailer is attached, apparently the previous owner had the round euro plug changed to the now 7 pin flat plug and on the other side has a Anderson plug which is great for me because that’s what my caravan is, but I still have the problem with the sensors going on in reverse, so any help would be much appreciated.
    Paul
    None original wiring in the car - the genuine trailer loom cancels the reverse sensors and does a few other things.
    Brisbane,some of the time.
    If its like the D3/4,and the van has LED lights,it will need resistors fitted,a search on here will reveal all.
    Once the resistors are in the rear light circuit,usually using a switch,the vehicle will go into tow mode.
    Mar 2022
    Australia
    Quote Originally Posted by 101RRS View Post
    any idea where to get the AU version so i can just plug it in and it’s all go.
    Paul
    Quote Originally Posted by Paulo1964 View Post
    Paul
    Its a LR part so anywhere that sells genuine LR parts (there is no AU version) - you need to check what is installed first - however you need to understand the LED trailer light issue as mentioned above - it could be as simple as that, so do a search on that first - there must be a thousand posts on this very common issue.
    Mar 2022
    Australia
    Thanks for the help I found this on YouTube LED trailer plug resistor wiring - YouTube so going to give this a try and see how it goes, price was $2.85
    Apr 2015
    Hervey Bay
    I be careful if you are going to follow that YouTube video. Those resistors might be OK for the indicators and brake lights due to only being powered up for a short time in normal driving. But a resistor like that on the tail lights would get VERY hot and probably melt your trailer plug, or worse catch fire.
    I'd go for the bigger resistors you can get off ebay and mount them where they can dissipate the heat build up.
    4PCS 50W LED Turn Signal Blinker Decoder Fix Hyper Flash Load Resistor | eBay
    04 L322 Vogue V8 - Work truck
    07 Freelander 2 TD4 SE - The wifes
    74 Leyland P76 Targa Florio - Aspen Green
    91 Kawasaki GPZ900R
    Previous LRs = 78IIa series - 81, 93, 95 RRC - D2V8
    Mar 2022
    Australia
    Trailer wiring
    Thanks for the heads up, makes sense with the park lights being on for a long time.
    Mar 2018
    Perth (near Malaga)
    Quote Originally Posted by FisherX View Post
    You only need them on the indicators in a D3/4.
