Results 1 to 10 of 19
Thread: TD5 head gasket
    Jun 2013
    Universe A
    TD5 head gasket
    What style and brand are currently considered to be the gold standard for a TD5?
    James
    Jul 2018
    Essendon
    Elring seemed to be the most recommended when I searched through various forums about 6 months ago.
    Nov 2014
    Nirvana near Albany W.A.
    Quote Originally Posted by shack View Post
    James
    Elring x 2
    I've been using Elring without problem for a number of years now.
    But style wise, dunno, I guess in the 5 big hole style
    Jun 2013
    Universe A
    Quote Originally Posted by discorevy View Post
    Elring x 2
    I've gone for the 5 big hole, 3 little hole style!
    I guess the Q in regard to style was MLS vs standard...
    Nov 2014
    Ah Ok, only ever seen coated MLS on TD5
    3 hole came off ?, has the head been off before ?
    Jun 2013
    Universe A
    Head has been off before, 3 hole gasket fitted, I know a lot of Mechs (not all) just order and put the 3 hole on, I've just gone the lazy route on this as well, performance difference should be negligible ...
    Hopefully.
    I've personally never had the head off this one.
    Nov 2014
    1 way to tell if the previous gasket was too thick as long as rings/ bores still in spec is a build up of carbon on the piston crown.
    The deficit of squish causes turbulence which presents as carbon build up
    I know it's difficult to be a Rural Landy mech and you generally have to get parts in before the job, which in this case meant a 3 hole gasket for you.
    I keep all 3 in stock and would like them to stay there, mainly because there are other things in life I'd rather be doing, but maybe I'm getting lazier as I age as well
    Jun 2013
    Universe A
    Thanks for the tip, in all honesty if I find that it needs a 1 hole gasket when I get it apart I'll probably order one, hopefully the previous fixer used the correct one... TWT
    Nov 2014
    I had no doubt James, the "she'll be right" approach doesn't seem like your style from what I can tell
    Jun 2013
    Universe A
    Head is off, gasket didn't look too bad, but I was still able to drive it a number of km after filling with coolant.
    This is the damage to head, does that look like it's got too hot to salvage?
    Of interest is that all of the head bolts would have been loose enough for my 12 year old to undo.
