TC input shaft seal fitting depth
					Can anyone advise the depth the transfer case input shaft seal should be?  The WSM only refers to the special tool that sets the depth.
I had my L322's gearbox output shaft and TC input shaft splines re-lubricated and the TC input shaft seal replaced by the local workshop.  However they appear to have made the same mistake they made with my D4 some years ago when its gbox was rebuilt wherein the seal was pushed in too far allowing oil to escape from a small hole normally covered by the seal.  There isn't a lip for the seal so without the tool and no depth measurement, unless one is aware of the small hole it would be easy to push the seal in too deeply.
Hopefully the new seal will be fitted this week, what's left of it, as it's my only transport apart from my truck.
				MY21.5 L405 D350 Vogue SE with 19s.  Produce LLAMS for LR/RR, Jeep GC/Dodge Ram
