Results 1 to 10 of 23
Thread: Whining noise
    Oct 2016
    Perth, AU
    Whining noise
    I enjoy a good bit of guesswork as much as anyone, so opening up to the forum: what is the high pitched whirring noise you can hear in the video?
    Some key points:
    - Usually only downhill, light accelerator
    - Has been getting more pronounced, though only slowly
    - Varies in pitch very directly with the accelerator - no lag to rev up/down the engine
    - Heavy accelerator, uphill, or high revs make it disappear
    - Typically around 1,500 - 2,000 RPM. Any more, and it vanishes
    - Sounds much louder than the video would have you believe
    - Sounds to be coming from the right side of the engine (ie, driver side in Australia)
    - No error codes (relevant ones anyway)
    2010 TDV6 3.0L Discovery 4 SE remapped to RRS output, Alaska White, GME XRS-330c, IIDTool BT, Dual Battery, Apple CarPlay, OEM Retrofitted: Cornering lights, Door card lights, Power + Heated Seats, Logic 7 audio
    Oct 2012
    Last of the Interceptors
    Jan 2017
    Geraldton WA
    Alternator ??
    4.6m Quintrex boat
    Feb 2009
    My car has a whine too, light acceleration approaching 2000rpm. Was thinking turbo but then the car's hesitating to shift up so I'm thinking transmission. Heavy engine braking (2500 to 3000rpm) can produce a much louder squeal.
    Yours is a bit more of a whine, perhaps?
    Now 2016 D4 HSE 'Leo' and Steve the Triumph Speed Twin
    Then 2010 D4 3.0 HSE 'James'
    Then 2010 RRS TDV8 'Roger' w traxide DBS, UHF, Cooper Zeons, Superchips remap
    Then 2010 D4 TDV6 'Jumbo' w traxide DBS
    First love 2002 D2 TD5 'Disco Stu'
    Sep 2014
    Baldivis WA
    Alternator or idler bearings. Is the noise present if coasting? If so, I'd be looking at wheel bearings, but they are normally more of a rumble.....
    Mar 2016
    Quote Originally Posted by Eric SDV6SE View Post
    The noise is aligned to the engine not road speed so it’s not wheel bearings. I’d look at something on the ancillary side like you say. Idler etc
    2007 Audi RS4 (B7)
    Sep 2014
    Bathurst, NSW
    Alternator was my first thought. How many Km on the Alternator. It seems like many have replaced theirs after 7 years or so. Mine was done last year at about 165,000.
    2014 SDV6 SE, Fuji White, ARB bar, Fyrlyt 5000, Pioneer Platform, Traxide D4-5S, Maxxis 980 Bravo, GOE Compressor Plate, ICom-450 UHF, Red Arc Tow Pro.
    Elite Murray 2 Caravan 24'4" Tare-2917kg, ATM-3500kg
    Oct 2016
    Perth, AU
    Thanks all for the responses so far
    Alternator was done about 90,000km ago, so I’d be disappointed if it had failed. The first one lasted to only 132k…
    Idler pulley sounds possible… not sure why only on a downhill though?
    Yes, coasting, but needs slight power to bring on the noise. I accidentally bumped a paddle shift under engine brake with a trailer on which also triggered it, but I’m guessing the engine still revved to match rpm with the gearbox or something?
    My own fear was turbo related…
    Sep 2014
    Baldivis WA
    Quote Originally Posted by veebs View Post
    Give it the berries and if it is a turbo, the red triangle will soon confirm it if it doesn't make boost.
    But seriously, Whine is usually from rolling element bearings, turbo's on these engines are plain (sleeve) bearings running on a hydrodynamic oul film, so I don't think its a turbo.
    What is odd is the rpm range of 500rpm where its most audible. A failing idler bearing would be noisy at all rpm, so maybe just starting to exceed allowable clearances.
    I like this guessing game
    Apr 2015
    Hervey Bay
    It sounds throttle dependant and sounds like a sucking noise.
    Air leak in the intake track linked with vacuum, noise disappears on boost, maybe.
    04 L322 Vogue V8 - Work truck
    07 Freelander 2 TD4 SE - The wifes
    74 Leyland P76 Targa Florio - Aspen Green
    91 Kawasaki GPZ900R
    Previous LRs = 78IIa series - 81, 93, 95 RRC - D2V8
