Results 1 to 10 of 28
Thread: POSSIBLE FIRE SAFETY WARNING.....
    Jun 2008
    The new Gold Coast, after ocean rises,Queensland
    I went to use my propane torch , you know , the one everyone has now , that snaps on
    to the left over propane canister from your portable stove.
    went to ignite a fire at home and opened the valve and pulled the trigger and gas and flames went everywhere. I had prescence of mind ......people often panic in fire situations.....to snap the valve closed and toss the lot away from me.
    the flames went out and I brushed all the burnt hair off my arms , went over and checked it wasn't too hot to touch and disconnected the canister which wasn't leaking.
    something had happened between the valve and the ignition system which was now cactus and appeared to have caused the problem.
    No user accessible bits there to look at so in the bin it went.
    I got out the stove which had been used to cook breakfast at home following a storm related power outage recently and put the suspect cannister in and gingerly fired it up.
    worked perfect.
    I contacted Qld Fires Services about the matter and they said they regularly get reports on these types of propane products all sold regularly at 4x4 outlets and the well known camping stores.
    they sent me safe operating booklet for best safe operation of portable butane/lpg campware which is available online if you wish to see it.
    just thought I'd throw this up here and as you all have these items go out asap and do a safety check on them, open the valve(s) , DO NOT TOUCH THE IGNITER , if there is any leakage you will quickly feel the cold gas or smell it. Or conversely ring the fire brigade and tell them you'd like a safety test done on your equipment and offer them a tray of lamingtons for their effort.
    cheers Dennis
    Jan 2010
    Another thing to watch out for with these is they can be left in the on/open position, so when snapped onto a can immediately start dispensing gas, as they don't have the safety feature like stoves, bbq's, heaters, that stop the gas when the can is removed, and will not reset the interlock until the gas control dial is turned to off.
    2005 D3 TDV6 Present
    1999 D2 TD5 Gone
    99.87 MB
    This type? I thought they had been banned. They're as sketchy as they can get!
    Slunnie
    Ireland
    I have one of those in the shed. Have not used it for a few years.
    Jan 2010
    The OP and I are referring to blow torches that fit on a spray paint can style gas cannister.
    1999 D2 TD5 Gone
    Quote Originally Posted by ramblingboy42 View Post
    I went to use my propane torch , you know , the one everyone has now , that snaps on to the left over propane canister from your portable stove
    I don’t have one of these torches. I’ll have to look in Bunnings for one. I have two of the stoves, one travels everywhere with me in my Rangie. Never had an issue with it.
    Brisbane,some of the time.
    We use the yellow LPG canister for work all day with no issues.
    In the vans we keep them in a sealed box vented through the floor,and always disconnect the torch from the bottle.
    Some companies won't allowe them stored even in a canopy of a dual cab ute,they have a container built onto the roof rack or roof rails,for the bottles.
    These small bottles are very common in our industry now as most also have small portable welding/brazing set,with one yellow LPG canister and an oxy bottle.
    More expensive to run than the old D size Oxy/Acet,but more convenient.
    There were a batch of cylinders that had leaking valves a few years ago and caused a couple of fatalities.
    Jan 2017
    Geraldton WA
    I can remember that they were taken off the market for a while because of issues with then , One of which was people putting hot plates and oversize pots/pans on them and blowing them up despite the warnings on the stoves (The new ones havs a raised area over the gas canister that prevents morons doing this).
    The other issue with some of the early ones was that the gas would ignite at the canister.
    I dumped the 2x early models I had when the new designs were introduced and got the newer type that I haven't had ANY dramas at all with other than the gas freezing up in really cold weather.
    I find them to be very efficiant and safe also the canisters are available pretty much Australia wide as well.
    I have had a couple of the little blow torches and I have binned them both, Dodgy dangerous little buggers I found then to be.
    4.6m Quintrex boat
    Oct 2007
    Brisbane West
    I think I have one of each generation of these stoves including a Greenstar from the first year they were released at least 20 years ago. Anyway I reckon they are excellent except in near freezing or lower temp conditions.
    This is my favourite. It is a weapon and very safe. Japanese made. 35FW Portable Butane Stove | Iwatani
    Sep 2012
    Westlake ,brisbane
    When we did our house renovations about 10 years back we cooked on one of these stoves for about 3 months plus . Our builder pulled out the old kitchen before the new kitchen had been ordered And again earlier this year we cooked on it for 2 1/2 months when we needed to replace our cook top , we were told cook top was in stock when ordered & paid for , then delivery was 4 weeks , then another 4 weeks , then another 2 weeks . We had to stick with this one because it was the only one that fitted the hole in the stone bench top.
    I don't like BBQ's so we don't have one .
